Traction control disable.. - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: Traction control disable..
    Dec 2002
    2002 SVT Focus
    Smile Traction control disable..
    The things you do on a rainy day...
    The SVT Focus has traction control.It can be turned off,but it still stays on until the car reaches 32km/hr. This makes hard launching impossible,and it's a real pain,especially at the track. .So I made a switch that plugs into the T/C fuse. This also disables the ABS ,but that's okay. The switch uses a blown fuse with a switch and fusable link soldered to it. I added a couple of connectors to make it easier to mount through a hole in the dash.
    So now I can launch hard at the track..
    FYI this is Davan's idea , I just made mine a bit different . Great idea Davan,it works great !!
    11 F-150 Supercrew FX4 5.0
    Canada
    '01 Toyota Celica
    hmmm...
    May 2004
    NW, Calgary
    1991 Honda Accord
    That is cool, hope it works out on the track, sounds like it will bypass, turn it off, good job.
    "If everything seems under control, you're just not going fast enough."
    - Mario Andretti
    Dec 2002
    2002 SVT Focus
    I mounted the switch in the lower dash.It works great !!
  1. 1996 old delta 88 abs and traction control problem
    By jizzdonor in forum Mechanical
    Latest Threads: 05-07-2004, 10:05 AM
  2. 2000 Sunfire Traction Control
    By TAXI34 in forum Mechanical
    Latest Threads: 05-02-2004, 04:58 AM
  3. Racelogic Traction Control
    By Joe Malms in forum General Car/Bike Talk
    Latest Threads: 04-26-2003, 10:06 AM
  4. Climate Control Units
    By iiinycboi in forum In Car Entertainment / Electronics
    Latest Threads: 12-27-2002, 12:25 AM
  5. JDM prelude climate control
    By AutodreamMarvin in forum Mechanical
    Latest Threads: 12-21-2002, 04:35 PM
