effects of parking a car long for long period of time? - Beyond.ca - Car Forums
Results 1 to 13 of 13
Thread: effects of parking a car long for long period of time?
    Apr 2003
    2015 Audi Q5 TDI
    Default effects of parking a car long for long period of time?
    Just wondering what are some effect of parking a car for long tim e without running it.
    Just say 1-2 months parked without running it. What are all the things that could happen?
    Aug 2002
    Canada
    DUBZ
    take your battery out
    Jul 2003
    Cup of Tea
    your tires might go flat and it can cause damage to them
    the oil dries up around your pistons so be carful when you start it up for the first time, just let it run for a bit so it gets lubed up again
    oreo cookie
    a wrx.
    2 months is nothing haha. just leave it alone.
    White Rock BC
    1997 Toyota Supra
    Rust, of course. Spray the underside with a wax based oil.
    Improperly drained fuel gelling in carb or fuel injection.
    Piston seizing (Run a little Rislone or other very light oil through the motor via the carb or F.I. and let it stall itself out)
    Squirrels and mice may hibernate in it.
    Paint damage if you leave it outside uncovered.
    Moisture getting in causing the interior to mold.
    Tire sidewall cracking over time.
    Spring sag, unless you put it up on jackstands.
    Remove the battery!!!
    However, in two months, the only thing that may happen is that your battery may discharge. Are you able to fire it up and let it reach operating temperature every week or 10 days? If not, take the battery out, and do not store it on the concrete where it will discharge faster. Store it on a wood bench in room temp with a trickle charger attached every few days.
    I'm somewhere where I don't know where I am...
    That Blue Car
    well i left my truck sitting for several months and it just fired up agian.... you should be fine, just bring a set of booster cables with ya when you go to get it.
    Apr 2003
    2015 Audi Q5 TDI
    it's on concrete.
    btw i just took my old car back out now after parking it for about 2 months.
    and i didn't let it warm up *doh* had to go work and at the likes i saw some smoke seeping outta the hood.
    which didn't occur befor i parked it? any reason for this?
    -Vincent
    That Blue Car
    could just be moisure burning off the exhaust manifold or something.
    Apr 2003
    2015 Audi Q5 TDI
    i hope so haha
    gonna get my oil change etc and see if everything is good.
    -Vincent
    Oct 2002
    335xi 70 c10 84 c10 Indian chief
    never put your car on jack stands when parking, your vehicle doensn't sit on jacks for the summer while u drive it, that can cause damage to your suspension alot worse then having it sit there ever could.
    Calgary,AB
    Porsche 911 Cab
    You might want to add some gas stabilzer to your tank, it keeps the gas somewhat fresh and prevents it from gumming up!
    I put fuel stabalizer in my motorcycle for the winter and have had no problems with it in the spring!
    Vancouver
    Infiniti G35 (wife's car) Me; Ancient Beetle
    Why is that? I have stored a vehicle on stands, as the nice wheels were removed, and the car sat for 2 years with no ill effects to the suspension. What is supposed to happen? I cannot imagine that shocks, ball joints, idler arms, cv joints or other components will fall apart. However if you have experience with this, please let me know so that I can correct a bad practice.
    Feb 2003
    Everyone will have a different opinion on this - for myself I'd just remove the battery (Don't store it on concrete!!). That's what I do for my summer and winter cars...
  1. Ground Effects = illegal?
    By Masta Dz16 in forum Cosmetic and Styling Modifications
    Latest Threads: 04-27-2004, 12:37 AM
  2. FS: Zoom 1010 Guitar Multi-Effects Processor
    By Mckenzie in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 04-12-2003, 11:45 AM
  3. rims or ground effects?
    By l/l/rX in forum Performance Modifications
    Latest Threads: 12-23-2002, 04:42 AM
