How did you guys run the wires and vac hose through dash. Did you somehow get it through the crack between the pillar and dash or did you drill a small hole in the dash? I'm using a thicker vac hose than the one that came with the autometer. Also what did you use as a power and ground source? thanks
edit- This is for a 94 civic if it helps any
