SSR to get the 400hp LS2
New for 2005
Gen IV 6.0L LS2 V-8 engine (390 horsepower/405 lb-ft torque)
Hydra-Matic 4L65-E four-speed automatic transmission (standard)
Tremec M10 six-speed manual transmission (optional)
New engine cover
Retuned steering system for more precise on-center feel and reduced low-speed effort
Revised exhaust routing – two pipes from muffler (quasi-dual exhaust)
“Dead pedal” design change to accommodate manual transmission option
Traction control button replaced with embossed SSR logo (manual transmission only)
Self-supporting gas hood struts
Sound system with CD player and MP3 playback capability (1SA package only)
New Regular Production Accessories (RPAs):
Auxiliary gauge package (volts, delivered torque, outside temperature)
Windbreak
Body color package includes body color on:
Auxiliary gauges (volts, delivered torque, outside temperature)
Engine cover insert
Pickup bed strips
Body color package with running boards includes body color on:
Engine cover insert
Pickup bed strips
Running boards
New bearing and low friction steering sealing package
Retuned valve and torsion bar to lower steering efforts
New exterior color: Aqua Blur (replaces Ultra Violet)
Revised driver’s side floor mat
Overview
Models: SSR
Body style / driveline: 2-seat convertible roadster with retractable hardtop / rear-wheel drive
Construction: 2-sided galvanized steel on exterior panels
EPA vehicle class: midsize truck
Manufacturing location: Lansing, Mich.
Engine
6.0L V-8 (LS2)
Type: 6.0L OHV V-8
Displacement (cu in / cc): 366 / 6000
Bore & stroke (in / mm): 4.00 x 3.62 / 101.6 x 92
Block material: cast aluminum
Cylinder head material: cast aluminum
Valvetrain: OHV, 2 valves per cylinder, camshaft in block, hydraulic roller lifters
Ignition system: electronic direct
Fuel delivery: sequential fuel injection
Compression ratio: 10.9:1
Horsepower (hp / kw @ rpm): 390 / 291 @ 5400
Torque (lb-ft / Nm @ rpm): 405 / 549 @ 4400
Recommended fuel: 93 octane recommended, not required
Maximum engine speed (rpm): 6500
Exhaust system: stainless steel with single muffler and dual tailpipes
Emission controls: evaporative system, catalytic converter, exhaust gas recirculation, positive crankcase ventilation
Estimated fuel economy
(mpg city / hwy / combined): TBD
Transmissions
Hydra-Matic 4L65-E Tremec T-56 (M10)
Type: 4-spd auto w/ overdrive, rear-wheel drive 6-spd manual
Application: std opt
Gear ratios (:1):
First: 3.06 2.66
Second: 1.62 1.78
Third: 1.00 1.30
Fourth: 0.70 1.00
Fifth: -- 0.74
Sixth: -- 0.50
Reverse: 2.29 2.90
Final drive ratio: 3.73:1 3.73:1
Chassis/Suspension
Front: double A-arm
Rear: five-link solid axle
Steering type: hydraulically assisted rack and pinion
Steering ratio: 16:1
Steering wheel turns, lock-to-lock: 3.05
Turning circle, curb-to-curb (ft / m): 38.1 / 11.6
Brakes
Type: power-assisted front disc, rear vented disc with four-wheel anti-lock braking system
Front rotor (diameter x thickness, in / mm): 12 x 1.14 / 305 x 29; discs
Rear rotor (diameter x thickness, in / mm): 12.8 x 0.78 / 325 x 20; vented discs
Total swept area (sq in / sq cm): front: 207.8 / 1340.4; rear: 216.6 / 1397.2
Wheels/Tires
Wheel size and type: front: 19-inch x 8-inch aluminum
rear: 20-inch x 10-inch aluminum
Tires: front: P255/45R19 Goodyear
rear: P295/40R20 Goodyear
no spare: repair and inflation kit provided
Dimensions
Exterior
Wheelbase (in / mm): 116 / 2946
Overall length (in / mm): 191.4 / 4862
Overall width (in / mm): 78.6 / 1996
Overall height (in / mm): 64.2 / 1631
Track (in / mm): front: 64.1 / 1628; rear: 64.9 / 1648
Minimum ground clearance (in / mm): 6.1 / 154
Curb weight (lb / kg): 4760 / 2159
Weight distribution (% front / rear): 52 / 48
Interior
Seating capacity: 2
Head room (in / mm): 40 / 1016
Leg room (in / mm): 42.1 / 1069
Shoulder room (in / mm): 53.5 / 1359
Hip room (in / mm): 51.3 / 1303
Capacities
EPA interior volume (cu ft / L): 39.9 / 1130
Cargo volume (cu ft / L): 23.7 / 671
Trailer towing maximum (lb / kg): 2500 / 1134
Fuel tank (gal / L): 25 / 94.6
Engine oil (qt / L): 5.5 / 5.2
Cooling system (qt / L): 16.1 / 15.2
Maximum trailer weight (lb / kg): 2500 / 1134
Performance Data
0-60 mph (0-97 km/h): manual: 5.29 sec
automatic: 5.49 sec
1/4-mile (.4 km): manual: 13.83 sec at 103.38 mph / 166.37 km/h
automatic: 13.95 sec at 99.2 mph / 159.65 km/h
50-70 mph (81-113 km/h): manual: 2.76 sec
automatic: 3.01 sec
93 Camaro Z28 (The fast one)
01 Trans Am WS6 (The cute one)
Esla T6 Dog Sled (Not cute, not fast, scary as hell)
