Looking for an older power supply to do some in home testing and setup of my car-pc... Needs to be have an ATX motherboard connector. Wattage isnt a big issue, 150-200w would do.
Not looking to spend more then $20 or so (depending on condition and age)
If you're not sure if you've got an ATX power supply, check the motherboard connector, will it plug into the white connector on the small board in the picture below?
