seeking help with system!! - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: seeking help with system!!
    Okotoks, Alberta
    88 CRX Si
    Default seeking help with system!!
    i just put my new system in the other day and im having this problem with it where my subs a reacting when they are not suposed to. iv had many systems before and this has never happened. for some reason my subs will go off when i hit my breaks or when i turn on my signal lights and even if i tap my dash the subs will be set off. i thought it might be my rca's picking up a signal somehow when i hit my dash and sending it to my subs but i put differant ones in and the same thing happened. anyone have any advice. please post back.
    2000 Maxima GLE
    i've had this problem before with an older amp ... i don't know what causes it but eventually after a day of driving around with it reacting funny the amp just died ... i let some guy take a look at it for me and when we opened up the amp it turns out that a bunch of wires inside the amp were cooked ... i don't know if that helps but maybe take it to get checked out... or get a new amp ...
    Jun 2004
    calgary, alberta
    01 s10 stepside
    a good cause of that is a short in ur channel. just the right movement can either cause it to ground out the subs, or simply make them not even work.. this can be fixed by any electroice shop.. cost i am not sure about.. but it is fixable. the best thing to do is to test each channel. if its a 2 channel then just hook one sub up on the left channel, then drive around for awhile,, see if goes away.. if not then try the other channel.. if u have a 4 channel(which i hope not for subs) then do the same..
    Jun 2004
    calgary, alberta
    01 s10 stepside
    p.s okotoks sucks..lol i used to live there..lol just playin with ya
  1. need help to power system HELP!!!!!!!!
    By cory27881 in forum In Car Entertainment / Electronics
    Latest Threads: 02-12-2004, 12:04 AM
  2. Putting together a System! HELP!
    By TalonVelocity in forum In Car Entertainment / Electronics
    Latest Threads: 05-30-2003, 03:44 PM
  3. Need help on new system
    By maskofdoom in forum In Car Entertainment / Electronics
    Latest Threads: 04-10-2003, 05:17 PM
  4. help with system
    By dj_honda in forum In Car Entertainment / Electronics
    Latest Threads: 10-08-2002, 04:08 AM
