Turbocharging an integra - Beyond.ca - Car Forums
Results 1 to 20 of 32
Thread: Turbocharging an integra
    '09 Acura TSX, '06 Ford F-150 Supercrew
    Default Turbocharging an integra
    Hi all,
    i am fairly new to the honda world, but have been modifying dsm's for about 6 years. My new project car is a 91 integra that i'm looking to turbocharge.
    As i see it this is what i need:
    Turbo (duh)
    Intercooler
    Custom piping
    Custom Manifold
    BOV
    Injectors
    Fuel Pump
    S-AFC
    Custom Exhaust
    Do i need anything else?
    Does anyone make a custom manifold for the B18A to a Mitsu turbo?
    Has anyone had fueling problems with these motors?
    Does the rest of the drivetrain hold up?
    Should i consider a VTEC head swap?
    any help would be appreciated.
    6.7 CUMMINS
    Don't bother with an safc. Grab an obd1 ecu, a harness and run uberdata. I can make you a basic manifold and downpipe for a mitsu turbo $650
    Similar to this
    IS250
    i was thinking about custom turboing my integra since ppl say its only around 2-3g
    but i have no clue where to start
    335i
    The AFC/injector setup is not easy to set up, nor very reliable. Uberdata is free, lots of guys here will help you out, and you'd end up spending about the same amount of dollars for a very good system - superior to the afc/injector setup.
    Btw - No one knows his turbo tegs like Legendboy - check out his manifolds, they are far superior and way cheaper to any store bought brands i've seen.
    As for an LS/Vtec turbo setup, unless you have 6k to do it, you won't get a reliable setup IMO. The ls/vtec is not cheap, and to reliably turbo it is a lot more expensive than talking to legendboy and the other guys around here on a custom setup.
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    May 2003
    2012 journey
    well here is a good starter if you are going to go turbo for a integra.. its a good read..
    http://www.beesandgoats.com/boostfaq/g2icturbo.html
    Apr 2004
    Turbod Honda
    www.homemadeturbo.com
    injector hack is for fags
    Nissan and Germany
    Do you warranty your manifold and downpipe by any chance? I'm thinking of going in this route for a TD05 18G. Very nice manifold, is it stainless steel?
    6.7 CUMMINS
    Yes my manifolds won't crack. No you don't get stainless for $650
    01 Carrera 4S, 05 350Z
    Get a Vortech FMU and check here: http://www.cse.uconn.edu/~yelevich/turbo/turbo.html
    All the info you need.
    Apr 2004
    your mom's bedroom
    POS
    LegendBoy. what kinda material made that manifold then since u say it's not stainless steel.
    For Rent: 1000 sq apartment located in Downtown. available immediately. Pls PM me for further detail
    Pm for detail
    6.7 CUMMINS
    cast mild steel 1/4" thick. i can do 304 & 316 ss as well in either 1/4" or 1/8" thick
    all my flanges are cold rolled mild steel, laser cut or cnc depending on where i get it
    Apr 2004
    Turbod Honda
    FMU? thats the stupidest idea I've ever heard.
    6.7 CUMMINS
    ya that was a pretty retarded post lol
    Apr 2004
    Nothing
    why isn't it a good idea? I use a sfmu in my Civic.
    HOOOOOObanger!!!!
    2 x E Class Benz
    An FMU is a hack, it won't give you a perfect Air Fuel Ratio. Not to mention you have zero control of timing with an FMU (it's just a fuel control device). Bad things happen when you run too rich or too lean, not to mention a loss in power.
    Apr 2004
    Turbod Honda
    i think there was already a discussion about FMUss on here. FMUs are for posers, people who buy kits, and cars that don't have any other means of altering the fuel tables/injector sizes.
    most people make the mistake of not using proper fuel management, such as a FMU, Rage pretty much covered all the problems with FMUs.
    Apr 2004
    Turbod Honda
    what year civic? what motor?
    6.7 CUMMINS
    meh its probably just something he heard on Tuner Transformation
    I see... hes got a b16a I think. Anyway a buddy of mine suggested the sfmu, so far he hasn't had any problems but bigger injectors would be a +.
    6.7 CUMMINS
    He obviously isn't making much power then
