My daytime running lights stopped working completely on my 1991 Civic Si... checked the fuse and it was fine... where should I start to diagnose the problem? Haynes manual wasn't any help...
anyone?
Isn't it a module?
check the wiring from the lamps back, maybe something got loose.
You can always turn your headlights on.
yeah but then i have a chance of leaving them on...its easy to forget in the daytime
how about, just not having headlights on during the daytime? i did that to my DRL because i have HID's and didnt want to screw em up and have em on during the day, i still have corner lights so people can see me, i just dont turn em on unless its dark, or bad visability
dont honda's have a chime when you leave the lights on?
Look in front of your car before you go away.
But anyway, check all your wires and if not look at a haynes manual. It cant be that screwed up!
i disabled my DRL's because the bulbs were running to hot. my relay was behind my passenger side kick pannel. hope that helps i drive a 90 teg
i had the same problem and my relay for them was done for so could be that very likely
