what size turbo, and who has it? - Beyond.ca - Car Forums
Page 1 of 4 1 2 ... LastLast
Results 1 to 20 of 71
Thread: what size turbo, and who has it?
    May 2003
    -10 F150 Lariat, -10 Fusion SEL awd
    Default what size turbo, and who has it?
    Hi, In the next few weeks here, I am planning on upgrading my turbo again. Bigger is better right? anyways. Its for a 1993 TSi Talon. I am shooting for 500-550HP. current mods are as follows:
    8.5:1 Wiseco pistons, with Eagle H-Beam Rods
    Cometic Head Gasket
    Balanced Crank
    Walbro 255 high pressure pump
    660CC injectors
    AEM EMS
    MAP/IAT conversion
    EVO 3 Big 16G
    soon to haves:
    HKS 264/264 cams (for streetability as opposed to 272's)
    BIG FMIC
    Turbo (this is the help i need)
    ported/polished head with dual valve springs
    What turbo do i need for this goal, and how much am i looking at spending? Im looking for a relatively quick spoolup for on the street, and it has to be capeable of high boost levels. I want to steer away from the Mitus 20 G as I have heard it takes forever to spool. What is the turbo experts suggestions?
    May 2004
    Okotoks
    Holy crap that thing must be a beast 500-550 hp.
    99 F355, 08 3500 Diesel Mega Cab, 12 Versa
    there is a very nice turbo for sale on the Canada Board. It's an FP3065, it will surely get you well over 500 HP!! Here's a link for it, I think he wants 1700 cdn which is a steal because they sell for 1279 US!!!
    Here's his info in intersted:
    Kevin Parent
    Contact: [email protected]
    He also has the 2 1/2'' Custom 02 housing for sale if interested!! This is a direct bolt on, a turbo I wouldn't pass up!!
    link: http://ca.dsm.org/
    Under: Wanted to Sell
    Thread Name: Performance Parting Out
    Apr 2004
    Turbod Honda
    garret super 60!!!
    May 2004
    FAT tires
    what forcefed said
    from everything ive heard those turbos are amazing.
    for a better price you could look at a garret t-66, but you loose the GT30 housing and the ballbearings
    either of those should put you well over 500whp
    in your list of soon to haves id switch up the 264's for 272's you will flow enough air to make good use of them, and for sure add an intake manifold.
    May 2003
    im just worried about idle and full boost with the 272's. This is still going to be a street car, so idle is pretty important to me, and I still use the A/C also!
    C.J.
    1997 TSi AWD 2.3L 6 bolt (Carillo Rods, Wiseco pistons, Cometic headgasket, ACL bearings, removed BS, FP3's, Crower springs/retainers, ARP hardware), FIC 950's, Aeromotive AFPR with SS lines, Walbro 255HP, PTE SCM61, Tial wastegate, Greddy Type S BOV, short route FMIC, 3" turbo back, AEM EMS, 3 bar map conversion, BJs SMIM, 75mm TB, Innovate LC-1 Wideband, 18" Focals, Bridgestone Potenza RE040's, Tokiko suspension.
    May 2004
    FAT tires
    well youll be using the EMS on the setup so setting your idle at say 1000 will be easy and will help smooth it out considerably.
    the 272's will hurt spoolup time, but were talking like a 200rpm window, so if it were me id live with it. Truthfully ive never seen nor heard firsthand reviews of the onboost power difference between the 272's and 264's, so im hopefully not talking out my ass. but what i have seen is a dyno chart showing that the big16g is just enough turbo to make full potential out of the 264's, so more turbo = more CFM = more benifit from bigger cams. and the 272's can theoretically flow alot more especially at higher rpm's and boost/CFM levels. so if im assuming correct (by the heavy duty valve springs) that youll definatly want to wind this motor up past 7K probably to 8+k then id definatly say youll see considerable benifits from the 272's.
    May 2003
    thanks tsi_neal
    does anyone know what kind of boost reponse i can expect from lets say a T-66? Is there any place in the city I can talk to, to get some more info (prices, wait, and a/r's)
    thanks
    C.J.
    May 2003
    Im not goot on my garrett turbo's so this might sound stupid, but:
    What is the difference between a 50 trim and 60 trim? What kind of power could i expect from a 60 trim t3/t4?
    C.J.
    Apr 2004
    Turbod Honda
    60 trim is bigger man
    May 2003
    how much power can they support?
    C.J.
    60 trim is good for about 500whp-525whp depending on your setup. I'm using one in my 944 turbo.
    It's gonna be one laggy turbo though with only 2.0L of displacement. I had a 57 trim on my 2.5L and I found it too laggy for my tastes. With the 60 trim turbo on my 2.8L, I found it acceptable.
    You might want to look into the GT series turbos... they have a much wider compressor map than the T3/T4 series, so you'll be able to flow a lot of power up top and still maintain half decent streetability. As much fun as a big turbo and that huge kick in the pants is, 2500-3000rpm wide powerbands suck ass.
    Can't wait till Hollywood reads my posts and responds .
    May 2004
    FAT tires
    im only guessing here, but forced performance claims full spool on a FP3065 to be somehting like 4K (what full spool is im not sure) and being a slightly less efficient exhaust housing and non ball bearing yet somewhat similar size id give the T-66 an extra 500rpm for full spool. There are ALOT of factors involved here and im not in the mood for doing research so take this guess for what it is.
    even a 60trim t3/t4 there are alot of variants on the specific wheels used. but a good 60trim should get you reasonably close to 500whp (475?) on pump gas. a 50trim will give you better spoolup times and probably 425whp on pump.
    as it sits with a very good setup your evo316g will get you 350-375whp, which will still be low 12's possible high 11's
    May 2004
    FAT tires
    Just read rage's post, remember that we have AWD driveline losses so we dont see as high WHP #'s as a rwd porsche...
    and the FP3065 is a GT30 series turbo that bolts up to a mitsu 7cm flange.
    500whp on pump gas? What kinda crack you smokin' there?
    Regardless of turbo, I'm guessing with 2.0L displacement and let's say cams and peak power at 7000rpm, the talon motor wont make more than 320whp on pump gas. Anything past that will require some pricey race gas.
    May 2004
    FAT tires
    heh, if you like ill dig up one guys DSM build thats seeing a little north of 500whp on pump (93 octane?) with a 60trim turbo
    EDIT: Ok to prove the internet benchracing loser that i really am... http://www.twingles.com/ideck/ and i was wrong its a 50trim turbo
    Find me a link, I'd really like to see a 500whp 2L motor on pump gas that doesn't melt itself.
    May 2004
    FAT tires
    ok, this one took some looking, but there is a bit more info on the setup. amazingly he has nothing terribly special, but awesome tuning skills
    http://www.dsmtalk.com/forums/showth...t=pump+AND+dre
    Apr 2004
    Turbod Honda
    lol, thats cool.
    Like I said, show me one that doesn't melt itself . That thing really is only good for dyno runs. It runs 6 degrees of timing. EGT's with that much ignition retard will melt pistons and valves in no time in REAL world conditions.
    Anything under 17 degrees of timing (generally) will hurt a motor over time. 6 degrees will have the manifold glowing bright red by the middle of 2nd gear... by 4th chunks of exhaust valves will be entering the turbine .
  1. Can someone suggest what size and what kind of tires are good for a 2004 WRX
    By yobi5888 in forum Cosmetic and Styling Modifications
    Latest Threads: 06-12-2004, 05:46 PM
  2. Alloy and tire size for '91 Civic???
    By Rembrant in forum General Car/Bike Talk
    Latest Threads: 02-23-2003, 08:25 PM
  3. WTB: wheels with 4x114.3 size and LOW offset
    By dogstar in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-14-2003, 01:16 PM
  4. wondering what size rims and tires i should get for my car...
    By Impreza in forum General Car/Bike Talk
    Latest Threads: 09-06-2002, 08:24 AM
