Originally posted by Weapon_R
Will you need new shocks regardless of how much you lower it? I only am gonna lower it 1.25"-1.50"...will that require shocks such as konis/kyb/tokico? And with an aftermarket shock, is the ride the same as a factory setup? IE-smooth?
If you lower your car and keep the stock shocks/struts, there is less available travel in the shock/strut, so they will wear out faster. Is your car a G2 or G3 Integra? because G2's ride really high, and if you lower in only 1.5", you'll wish later that it was lower. When lowered with stock shocks/struts, I've heard that the ride is bouncy. With performance shocks/struts and springs/coil's your ride should be better then stock suspension.
Current Cars:
2004 GMC 2500HD 8.1L
Past Cars:
1970 Chevy Blazer, 2wd
2005 Jeep Wrangler LJ
1989 5L Mustang
1990 Jeep Cherokee
