I've heard conflicting claims that these either
a) Do wonders for performance gains
b) Don't do anything at all
Is there anyone who has installed a high flow cat and can comment on this?
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
doesn't do much for performance.
thanks
every situation is different. what kinda car, what kinda mods u have already...etc.
It won't help you much. The stock cat is actually pretty darn good. The only time I would even think to get one is if you are getting a fairly large diameter aftermarket header/exhaust combo. And the only reason I say that is because it's kinda gay to go from a 2.25" collector to a 1.75" cat to a 2.25" exhaust. Plus, I'm assuming that if you have a large diameter exhaust you have the engine mods to push the extra fumes.
or jdm header 2.5inch
Go with a test pipe if you don't mind the noise
And if you DO mind the noise, get a turbo!Originally posted by cocoabrova
Boost is your friend
Random Technology Cat if your looking for a hi flow cat.
Big improvement w/ a turbo, not too bad w/ non and helps the exhaust system last longer...
hey I was wondering, is it still consideribly loud if I have just a test pipe, but with a turbo, or is it all the same and the car isnt that loud at all
