How to build your own CAI? - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: How to build your own CAI?
    Apr 2004
    Uranus
    Question How to build your own CAI?
    How would I go about doing so???
    I'm somewhere where I don't know where I am...
    That Blue Car
    find out the lengths and angles you need, go to an exhaust shop and get some 3" madrel bent at whatever angles and lengths you need... go to home depot get soem rubber couplers and a bunch of 3" hose clamps... get a knn cone filter with a 3' hole, and put it all together.
    2.8,... I can get one made for you
    Apr 2004
    Uranus
    how much are we looking at?
    wait a min,... do you have the big ass MAF sensor inline between your air box and TB?
    Apr 2004
    Uranus
    yeah
    T2S
    pedals
    vacuum hose i where its at. fo shizzle
    Aug 2003
    edmonton
    garbage truck
    go to home depot
    Aug 2002
    '10 RX350 & '08 e90 335i
    If your that concerned about cost just get a cheaper brand after mareket one IMO
    Autosignature
    CowTown
    Brick Type R, SC AW11, Alcyone
    Ebay and then get a new filter...
    omgwtfbbq
    Apr 2004
    i think he would get an aftermarket one, but i dont know of any companies that make one for an 89 corsica
    Apr 2004
    Uranus
    ^^^ exactly
    any corsica sites ive seen theyre all custom made ... so yeah, I'd have to do the same
    You're gonna have to reseach how to swap out your current MAF sensor and put in the IAT or maybe it's a MAT (I believe that's what it's called),.... from the 3.1's. (on the side of the air box).
    But anyways,... your stock MAF sensor is very restrictive,... it's a tube with a screen/grate in the middle and on the screen is a sensor,.... not a very cool set-up.
    Maybe post on your corsica sites you've visited and see how to swap sensors,... cause your MAF sensor is I think 5 wires,... but the new sensor is only 2,... not sure what wires you need. or you could just mount the sensor elsewhere in the engine bay (probably where the most cold air is), but ask your corsica buddies if this'll cause a problem,.. then I can get a pipe for you.
    Apr 2004
    Uranus
    k...i looked all up in there and there's 2 things i can see that restrict me from ripping it all out...
    a) a small rubber tube at the base of the intake (closest to engine) that connects to the top of the block
    b) the sensor on the AIR BOX its not MAF its 2 wires connected to the back side of the air box
    if i could take some pics to show you i would but i cant damnit
    anyways, can i work with this? a buddy told me the tube was just one of those anti pollution setup things, nothing important...and he said what you waid, to pull the sensor on the air box out and mount it wherever the air is cold enough......
    That pcv tube attached to your intake from the block (valve cover),.. you don't even need that hooked up,.. just put a small filter on the block side.
    That is one main source that will gum up your TB,... when you engine runs hot,.. and you're low on oil,... the oils turn into gasses and recirc. into your intake,.... and when you car cools down,.. all that reside on your TB gums stuff up.
    I know that sensor on the air box is not a maf,... just wasn't sure what system you were running,... some older 2.8's had that big ass sensor inline between the box and the TB.
    You should come over to my place one day and look at my set up,... we basically have the same motor.
    Apr 2004
    Uranus
    we'll have to set something up sometime then
    and perhaps then you can see what i need for a pipe and you can hook that up too but ya dont have to...
    but it would be nice to see your setup and give me some ideas
    pm me when yer available sometime and we'll fingure sumthin out
    YOu basically have to same motor as me,.. so hense the set-up could be almost Identical!
    And if so,.... It'll be a flash to have a pipe made up,... we'll just replicate mine.
  1. Build Own Computer...
    By TalonVelocity in forum Computers, Consoles, and other Electronics
    Latest Threads: 06-05-2004, 10:59 AM
  2. Build your own Mercedes Benz!
    By nex in forum Cars, Bikes, Machines
    Latest Threads: 09-29-2003, 12:26 AM
  3. Build your own Benz
    By Gripenfelter in forum General Car/Bike Talk
    Latest Threads: 05-28-2003, 06:13 PM
  4. Port And Polish On Your Own
    By ConVict in forum General Car/Bike Talk
    Latest Threads: 10-09-2002, 12:31 PM
  5. to all you guys starting your own clubs....
    By buh_buh in forum General
    Latest Threads: 06-01-2002, 01:03 AM
