Im just trying to figure out what kind of welding i should be doing to fill the holes in my door after i remove my door handles
MIG. Have you ever welded before? Your question leads me to believe you haven't. If not, practice on scrap the same gauge ALOT before you try (spot weld @ even intervals, and stitch weld the rest, jumping around the perimeter.) , or get a professional to do it for you.
A door skin is one of the easiest panels to warp if the heat gets to be too much. Take your time, and cool the panel down with a wet rag after each stitch.
I can help you out if you need the work done. Let me know.
