low boost w/ med compression vs. high boost w/ low compression? - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: low boost w/ med compression vs. high boost w/ low compression?
    2008 Z06
    Default low boost w/ med compression vs. high boost w/ low compression?
    Medium CR being 9.4 and Low being =< 8.8
    Low boost being 6lbs and high being 9lbs+
    Type 1 = low boost w/ med compression
    Type 2 = high boost w/ low compression
    The following is IMO only.
    So the main difference with these engine setups is going to be the way the power curve looks. Type 2 is probably going to be more rev-happy, where type 1 is probably going to be a better daily driver.
    discuss
    Current Cars:
    2004 GMC 2500HD 8.1L
    Past Cars:
    1970 Chevy Blazer, 2wd
    2005 Jeep Wrangler LJ
    1989 5L Mustang
    1990 Jeep Cherokee
    Jul 2002
    '15 GTI
    IMO 9lbs is not high boost, 9lbs can be run on factory internals given its not super high compression to begin with, however theres probably reliability issues
    Fuji's Avatar
    Fuji is offline Track Events Co-ordinator
    cars
    Hey! how about High Boost and High Compression! BOOM!
    With low compression motors, you have the ability to run high boost with low octane fuels (pump gas). High compression motors, you will need exotic fuels to run the same amount of boost. Shitty thing with low compression motors, is off boost, there is NO power/torque at all. It's a dog around town, and fuel economy drops (obviously).
    When you lower compression on a motor, you will need more boost to make the same power (less compression, less cylinder pressure). For example, a 11:1 compression motor at 6psi will make the same power as an identical motor but with 8:1 compression motor at 12psi (not exact numbers, but you get the idea). The 8:1 motor will be a dog when the turbo isn't spooled up though, and fuel economy will be worse, but it can make more power with the same octane fuel by allowing more boost before detonation.
    The secret is to find a good balance, like the 911 twin turbo, running mid compression (10:1 I think) and a maximum of 12psi. This will give excellent peak power with decent off boost torque as well.
  1. Good Audio Compression formats?
    By GTS Jeff in forum General
    Latest Threads: 11-28-2002, 05:11 PM
  2. Just got the Teg back from a compression test
    By Ekliptix in forum General Car/Bike Talk
    Latest Threads: 09-14-2002, 10:30 PM
  3. what do you look for in a compression test?
    By 2000impreza in forum Mechanical
    Latest Threads: 08-20-2002, 03:04 PM
  4. Brake rotors... high and low quality??
    By homie in forum General Car/Bike Talk
    Latest Threads: 07-13-2002, 03:54 PM
  5. AMG vs honda (on low boost!)
    By redline in forum Cars, Bikes, Machines
    Latest Threads: 05-27-2002, 02:00 PM
