did a swap from mpfi to dpfi put in new ecu and dizzy form 91 si motor (honda civic) was wondering if anyone doin a engine swap like this ahs had this problem??
TTT
its in lit mode...
lit mode?
do you still have the same amount of power before 3000 RPM or no, if it is less, try doing a swap on your fuel filter, and pump, but if it is something else, I am stumped
Lifes for the living, so live it...
What is lit mode and it seems to have the same power other than not going over 3000
ok so my crank positining sensor was light up on the ecu?? bad dizzy is that all that can mean?
did you wire the crank position sensor when you did the wiring swap?
umm you know what im not 100% sure i forget i think i did i will check, where would i ahve ran it form??
bump
