Wont Rev Past 3000rpm - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Wont Rev Past 3000rpm
    May 2004
    1990 Civic HB
    Default Wont Rev Past 3000rpm
    did a swap from mpfi to dpfi put in new ecu and dizzy form 91 si motor (honda civic) was wondering if anyone doin a engine swap like this ahs had this problem??
    May 2004
    1990 Civic HB
    TTT
    Aug 2003
    edmonton
    garbage truck
    its in lit mode...
    May 2004
    1990 Civic HB
    lit mode?
    Worsley, Ab
    '97 GMC Sierra 1500 Z71
    do you still have the same amount of power before 3000 RPM or no, if it is less, try doing a swap on your fuel filter, and pump, but if it is something else, I am stumped
    Lifes for the living, so live it...
    May 2004
    1990 Civic HB
    What is lit mode and it seems to have the same power other than not going over 3000
    May 2004
    1990 Civic HB
    ok so my crank positining sensor was light up on the ecu?? bad dizzy is that all that can mean?
    May 2003
    89 colt gt 4g63
    did you wire the crank position sensor when you did the wiring swap?
    May 2004
    1990 Civic HB
    umm you know what im not 100% sure i forget i think i did i will check, where would i ahve ran it form??
    May 2004
    1990 Civic HB
    bump
  1. Past vehicles you owned?
    By SchoolN'U in forum General Car/Bike Talk
    Latest Threads: 05-10-2014, 09:46 AM
  2. over rev or under rev?
    By Rockski in forum Mechanical
    Latest Threads: 08-18-2004, 02:00 PM
  3. past Pshop contests
    By Honda Attack in forum Photoshop Gallery
    Latest Threads: 07-01-2003, 09:46 PM
  4. How fast are you going at 3000RPM? in highest gear
    By Ekliptix in forum General Car/Bike Talk
    Latest Threads: 05-06-2003, 07:24 AM
