Connecting a tv as a monitor to a laptop - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: Connecting a tv as a monitor to a laptop
    The depths of despair!
    Anything topless.
    Default Connecting a tv as a monitor to a laptop
    So can I do this? I'm not exactly sure. I have a video out jack that takes a standard rca plug, but what I'm wondering if it will just hook directly into a tv that has the same plug. If anyone knows, let me know. thanks
    WTF!! I am a moderator!!
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    yeah should work like that now probs
    Oct 2004
    03' Silverado 1500 & 2500, 04 g35
    It will work but your desktop will be very fuzzy.. 640x480 max resolution. You should also have a program or a button with your laptop(this button might require software to work) that will switch it over. Or some machines will go straight to the tv if the jack is plugged in when you boot up.
    I only use it to play downloaded movies.. for some reason once you maximize a movie its perfectly clear.
    Bicycle
    Are you in Korea? I may have mistaken with another member......
    Anyhow, some laptop will go up to 800X600 but that's as far as it goes. Only good if you play movies or play arcade style games, sucks for everything else.
    And IF you ARE trying to do this in Korea, make sure they are NTSC.
  1. Connecting JL sub assistance
    By mike70707 in forum In Car Entertainment / Electronics
    Latest Threads: 10-14-2004, 11:51 AM
  2. connecting air/fuel ratio gauge??
    By vtec in forum Mechanical
    Latest Threads: 05-29-2004, 12:59 AM
  3. Connecting a KOSS MSP8200
    By stranger_78 in forum In Car Entertainment / Electronics
    Latest Threads: 05-08-2004, 10:56 PM
  4. IRC: Problems connecting to dalnet...
    By nismodrifter in forum General
    Latest Threads: 01-27-2003, 06:06 PM
  5. connecting subwoofer to a 2 channel amp
    By inspire in forum In Car Entertainment / Electronics
    Latest Threads: 12-10-2002, 01:30 AM
