amp problems! - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: amp problems!
    Oct 2002
    Default amp problems!
    installed my amp today!! the amp works fine, however, when i listen to the radio it works fine, but when i switch to cd no sound is produced, the graphic equalizer thingy shows that music is played, but i cant hear anything!! i dont know what to do!!
    NOR/CAL
    a nice pair of and1's
    tried different CDs? what kind of deck is it? i doubt it's your amp acting up because if radio works fine then there's no reason why CD won't work
    Oct 2002
    it is an alpine 7894
    NOR/CAL
    were u listening to mp3s? or just a regular CD?
    (maah raahde)
    Kinda off topic, but did you do the install yourself? How much did all the wiring cost you?
    Oct 2002
    i tried switching cd's....still wont work!! fuck, this is pissing me off!
    Oct 2002
    redline13000 did the install...thx man!
    NOR/CAL
    ok, i know for my deck there's an option that changes the audio levels of each input, ie radio, cd, and aux, is there something like that on your deck?
    4cyl turbo diesel with a max speed of 10.9kmh
    np...yo guy try turning the AUX off..i think i might have turned it on
    Oct 2002
    i dont think so....i just checked in the manual, cant see anything regarding that
    NOR/CAL
    hmm that's weird.. how new is your deck?
    Oct 2002
    like 1 month
    NOR/CAL
    bring the deck back to the place you bought it, something might've shooken loose when u were installing. usually doesn't happen but it can happen, it's not outputting the CD signal.
    Oct 2002
    Airdrie
    CH9
    Is the amp on when you are playing cd's?
    What colour remote line did you use on the deck blue or blue/white?
    If you used the blue wire you used the ant. power wire and not the amp remote wire. If this is the problem then the amp will turn on with the radio but not the cd.
    Just a thought check it out.
    Oct 2002
    the deck is on while playing cd's as well as the radio,
    thanks for your help tho!
    Oct 2002
    ok, i was playing around with the amp today and i cant figure out what is wrong!
    when i use the radio on my deck, the amps power light is on, however, when i switch my deck to play a cd, the amps power light turns off...
    what should i do?
    Oct 2002
    Airdrie
    CH9
    If the remote wire for the amp is connected to the blue on the cd player you will have this problem. Hook up the remote line to the blue wire with a white stipe. this WILL solve your problem.
    Oct 2002
    thx 95acc!! u were right!! i fixed it
    Oct 2002
    Airdrie
    CH9
  1. FS: Guitar Amp: Crate G600 Head & 2x12 Cabinet
    By three.eighteen. in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-13-2002, 02:50 AM
  2. Hondata problems & CELS
    By Dirty_SOHC in forum Mechanical
    Latest Threads: 11-14-2002, 09:14 PM
  3. fs: 2 12" MTX Blue Thunder Subs & MTX 1502 Pro Amp
    By Ed the SOHC in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-06-2002, 07:01 PM
  4. Tranny Problems
    By ConVict in forum General Car/Bike Talk
    Latest Threads: 07-04-2002, 09:46 PM
  5. Car problems
    Latest Threads: 06-14-2002, 12:23 AM
