How do I "Change Gears" - Beyond.ca - Car Forums
Results 1 to 4 of 4
Thread: How do I "Change Gears"
    9.872604, -85.498802
    A Ford and a Caddy™
    Default How do I "Change Gears"
    To curb a lot of PM's and Posts, this is what you need to change gears under your user name.
    Newbie (Minimum Posts: 0)
    Neutral (Minimum Posts: 100)
    First Gear (Minimum Posts: 350)
    Second Gear (Minimum Posts: 1200)
    Third Gear (Minimum Posts: 2500)
    Fourth Gear (Minimum Posts: 4000)
    Fifth Gear (Minimum Posts: 6000)
    Sixth Gear (Minimum Posts: 9000)
    Seventh Gear (Minimum Posts: 10000)
    Redlining 7th Gear (Minimum Posts: 12500)
    I just want to add excessive whoring to get to the "next gear" will reset you to 0.
    A Ford and a Caddy™
    And/Or get you banned.
    Cougar Town!
    Gear Ratio Change
  1. sticky gears
    By Daxin in forum Mechanical
    Latest Threads: 10-25-2003, 12:43 PM
  2. What is the post count to "Switch Gears"?
    By R-Audi in forum Suggestion/Comment Box/Forum Related Stuff
    Latest Threads: 07-04-2003, 01:25 AM
  3. Hayame Cam gears for H22
    By shadowz in forum Automotive Parts
    Latest Threads: 05-29-2003, 12:51 PM
  4. boost in lower gears
    By LUDELVR in forum Mechanical
    Latest Threads: 06-23-2002, 02:03 PM
  5. Installing New Gears?
    By Weapon_R in forum Performance Modifications
    Latest Threads: 06-20-2002, 12:31 AM
