Airbag disconnect - Beyond.ca - Car Forums
Results 1 to 6 of 6
Thread: Airbag disconnect
    Feb 2004
    Beiseker, Alberta
    74 Nova-92 RMW-08 Aura XR-94 Sierra
    Default Airbag disconnect
    does anyone know where I could go just to get the airbag disconnected so I can pull the column apart to fix my brake light/turn signal problem!?
    This is on my 94' Olds Cutlass
    2008 Saturn Aura XR- 3.6L 6spd Modded on 20's
    1994 GMC Sierra Z71 RC/SB 5spd Lifted on 33's
    1992 Buick Roadmaster Estate Wagon-"Got Wood?"
    1974 Chevy Nova 406ci Never ending project!
    2013 Hyundai Veloster 'Sublime Detail' Company car
    & Many More...
    Calgary, Ab
    Get a Haynes manual at Crappy tire or the library. Tells you how to disconnect/remove your airbag.
    Damn +44411's
    I'm somewhere where I don't know where I am...
    That Blue Car
    all you have to do is unhook the battery and pres the brake for 15 seconds (to drain any power that may be in the system) and then have at er.
    Feb 2004
    Beiseker, Alberta
    I'm so paranoid about it going off.
    Does anyone know if it is illegal not to run an airbag wheel in the car. Even if I will keep the airbag and install it back in the car if I sell it?
    & Many More...
    Oct 2004
    Exeter, UK
    Modified Ford Escort 1.6 LX
    Im installing some bucket seats into my car and have been told I have to permenantly disconnect the air bag Can't really see what difference it makes (obviously if you re involved in accident) because if you change the steering wheel from the standard one you wouldn't have an airbag anymore.
    '07 Ranger FX4 Level II
    Default Re: Airbag disconnect
    disconect the postive terminal from the battery, wait 2 minutes for the ABCM to turn its self off.
    Under the dash, about 2 feet from the stering wheel down the coloum the wiring harness will come out, find the big fat yellow wire that is by its self, remove the plastic orange lock pin, and disconect the wire.
    make sure you plug that back in before you hook the + back up, or the abcm will think its blown, and the air bag light will flash till the abcm is replaced
    Originally posted by rage2
  1. How to Disconnect power antenna
    By topher91 in forum Mechanical
    Latest Threads: 11-01-2003, 03:41 AM
  2. RSX Airbag
    By Ibangedyourmom in forum Mechanical
    Latest Threads: 09-18-2003, 12:14 PM
  3. bmw 3 spoke sports steering wheel w/ triangle airbag..
    By Clem in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 12-20-2002, 12:20 AM
  4. aftermarket steering wheel and airbag removal?
    By 2000impreza in forum General Car/Bike Talk
    Latest Threads: 09-14-2002, 11:44 AM
  5. Reseting SRS/airbag light
    By Ferio_vti in forum Mechanical
    Latest Threads: 07-14-2002, 06:04 PM
