wont rev past 3000 rpm - Beyond.ca - Car Forums
Results 1 to 15 of 15
Thread: wont rev past 3000 rpm
    May 2004
    1990 Civic HB
    Default wont rev past 3000 rpm
    posted b4 tryin again
    did a swap form my 4th gen put in a 1993 dx motor so i had to do the mpfi swap as well wire in a new dizzy and injectors and ecu
    now it wont rev past 3000 and my ecu says code 4 (crank angle sensor) which is supoposed 2 be the dizzy i ahve tried 2 dizzys and double and triple checked the wiring anyone help??/
    sorry
    May 2004
    1990 Civic HB
    what??
    Vancouver
    1993 Nissan 240sx
    what's a dizzy?
    Originally posted by africano
    what's a dizzy?
    Distributor
    Oct 2003
    91 PP1 - 93 EH6 - 01 BB6
    I know you've checked over everything repeatedly, so bear with me cuz I don't know the specifics of your swap. Did you use the 93 dx harness with your 90 bay harness? is everything pinned to the ECU correctly?
    May 2004
    1990 Civic HB
    dizzy+distributor i thought that was common knowledge
    and Primerdrift i used my old 90 harness and switched the 91 si ecu and dizzy inwirin seems all right going to the ecu
    maybe one day someone could come and double check but it all looks right
    Dec 2002
    EF ZC-T, EK-T, Blazer, EF
    is it a 91 si dizzy?
    May 2004
    1990 Civic HB
    supposedly yes
    Oct 2003
    eeseen do you have both harnesses?
    May 2004
    1990 Civic HB
    um yes i do
    Did you swap the pins at the ECU?
    May 2004
    1990 Civic HB
    ya we did swap the pins
    Oct 2003
    Sorry for the dumb post eeSeen, I was in a hurry. I was going to say If you have both harnesses, retest the bay connector to distributor connector on both harnesses, if they are the same pins then that eliminates that. Then move on to engine bay harness to ECU, if the pin out matches your wiring diagram check for any pins in the ecu connector and bay that might not be pushed in all the way.
    May 2004
    1990 Civic HB
    k i will check thanks
    any other ideas?
  1. Past vehicles you owned?
    By SchoolN'U in forum General Car/Bike Talk
    Latest Threads: 05-10-2014, 09:46 AM
  2. Wont Rev Past 3000rpm
    By eeseen racing in forum Mechanical
    Latest Threads: 10-02-2004, 04:23 PM
  3. over rev or under rev?
    By Rockski in forum Mechanical
    Latest Threads: 08-18-2004, 02:00 PM
  4. past Pshop contests
    By Honda Attack in forum Photoshop Gallery
    Latest Threads: 07-01-2003, 09:46 PM
