wiring power - Beyond.ca - Car Forums
Results 1 to 5 of 5
Thread: wiring power
    2018 Ford F150 SCREW
    Default wiring power
    i am running a jl 12w0 behind the seat in my truck and it is going off od a bridged phoenix gold 90x2. this amp is wired with canadian tire wire. 12 gauge. if i upgraded this to 8 gauge would i notice a difference or is it even worth it.
    (maah raahde)
    Probably not at all.
    T2S
    pedals
    depends on the amp. With a powerful amp, you will notice a bit of a difference. It is worth it. Kinda a pain in the ass, but any sub setup in a stereo should be done with at least 10 gauge wire. 8 will be great for you. The difference will prob. be when you have it loud. Even if you dont notice a difference, your system will run better. Its still your choice, and its too bad you didnt use 10 or 8 in the first place, but i would do it.
    Oct 2002
    Airdrie
    CH9
    You should NEVER run an amp with less than 8awg. Upgrading your power wire WILL make a difference.
    Think about this....try sucking a milkshake out of a swivel stick...lots of work right? now us a slurpee straw a whole lot easier. same applies to current in a car audio system the bigger power wire the better.
    (maah raahde)
    Oh shit, you were talking about power/ground?? I thought you meant speaker wire! Hahaha!
  1. Rockford wiring kit
    By ramminghard in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-02-2003, 05:42 PM
  2. Wiring an amp
    By ramminghard in forum In Car Entertainment / Electronics
    Latest Threads: 12-30-2002, 08:25 PM
  3. Amp wiring kits
    By silverEL in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-28-2002, 06:38 PM
  4. Sub/Amp wiring kits
    By dj_honda in forum In Car Entertainment / Electronics
    Latest Threads: 10-20-2002, 09:05 PM
  5. wiring
    By redline_13000 in forum In Car Entertainment / Electronics
    Latest Threads: 08-15-2002, 08:23 AM
