Wastegate issues? - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: Wastegate issues?
    Jun 2004
    1990 Eagle Talon TSI AWD
    Default Wastegate issues?
    help please
    i am gettin some extreme wastegate-like noise from my 90 Talon TSi from about 2800 revs and up
    i briefly checked my ic piping and it seems ok
    could it be the wastegate spring?
    any help/suggestions/donations would be greatly appreciated.
    Sep 2002
    I dont Drive
    have you noticed any boost loss?
    Jun 2004
    ummmm ALL!!
    i am getting no boost or power absolutely whatever. I am running on a 7.8:1 compression ratio and that is it!
    Dec 2003
    Jeep
    Originally posted by 90TSI
    ummmm ALL!!
    How close did you check the IC pipes? Call me a Caveman, but if you're getting no boost my immediate guesses in order go like this :
    1) Hose is off or broken
    2) Wastegate is basically wide open almost all the time.
    Do you have a pressure tester to test the pipes? Does you boost gauge even move out of vaccuum?
    Jul 2003
    Lifted 4.0L H.O.
    Wastegate issues? Try this....Its most likely a vacumn hose.
    Rev high, ride low.
    Nov 2004
    yea, umm check that shit y0
    Jun 2004
    Thanks very much for everyones suggestions and keep em comin.
    For JCX, both intercooler hoses are secured in place and dont seem to be broken. I dont have a pressure tester and my STOCK boost guage (not too reliable) is getting out of vacuum, and im hitting about .5-.7bar on it. The wastegate is what i thought it was. How much do they usually go for?
    For switchblade, which vacuum lines would you be talking about?
    thanks again everyone.
    Jul 2003
    Lifted 4.0L H.O.
    Default vac line
    Check the black one coming off the wastgate for cracks or leaks.
    Rev high, ride low.
    E36 4dr
    If your wastegate looks like the one above, check to make sure the leg of the wastegate is actually connected to the wastegate flap on the turbo. (Blah, i don't know terminology)
    Mine came off under boost and resulted in the same scenario as you have right now.
    Feb 2004
    Calg.
    1ST GEN
    The thing your talking about is not the wastegate, it is the wategate actuator. The wastegate dumps the excess boost into the exhaust. the actuator regulates this. You would know if you wastegate was malfunctioning. If it was seized, you would build so much boost that your motor would explode. If was wasn't holding, usually caused by the actuator, you wouldn't build any boost (or very little). That could be the problem. Talon actuators are known to go since it is just a rubber diaphram inside and a spring. Because it is 14 years old, it is probably pooched. Change it and see. Dealer charges an arm and a leg for them but if you go to www.machv.com they are much less. I think www.extremepsi.com carries them to. Might be something to look into. Instead of buying one, maybe a friend could lend you one for a try. Make sure the car is cool when you change it, it will make things much easier. Won't be as much like the boardgame "Doctor".
    Feb 2004
    Calg.
    1ST GEN
    Revolution Motorsports
    (780) 713-8545
    Ron there can get them in too. Might be easier cause then you don't have to worry about exchange, duty, or brokerage fees. Give him a call for all your DSM needs.
    Nov 2004
    no man.
    Feb 2004
    Calg.
    1ST GEN
    Originally posted by vegas2005baby
    no man.
    Anyone care to elaberate?
    a van down by the river
    Bmw and ford
    wastegate diverts exhaust away from the turbo so it does not make more boost
    Aug 2002
    Westside - Airdrie, AB
    08 Acura CSX-S Gone:1991 DSM Laser / '96 VW Jetta
    I'd check out some DSM related sites for your questions....
    www.vfaq.com is a good one
    www.dsmtuners.com has a good tech section and you could probably try searching on thier forums for what you described.
    But yeah I'd check your wastegate actuator and make sure its not seized open.
    If you need a new/used part check out www.calg.dsm.org forums or even on this site. I think some one's parting out thier Talon in the misc. parts section.
    According to www.howstuffworks.com ....
    The Wastegate
    Most automotive turbochargers have a wastegate, which allows the use of a smaller turbocharger to reduce lag while preventing it from spinning too quickly at high engine speeds. The wastegate is a valve that allows the exhaust to bypass the turbine blades. The wastegate senses the boost pressure. If the pressure gets too high, it could be an indicator that the turbine is spinning too quickly, so the wastegate bypasses some of the exhaust around the turbine blades, allowing the blades to slow down.
    Aug 2004
    kelowna
    Ive got a wastegate actuator 45$ let me know
    Dec 2002
    2004 Toyota Echo
    I can help you see if you have a boost leak. Let me know.
    2004 Toyota Echo
  1. Wastegate issues?
    By 90TSI in forum Mechanical
    Latest Threads: 11-20-2004, 12:05 PM
  2. Re: Wastegate Issues?
    By 90TSI in forum Forced Induction Talk
    Latest Threads: 11-07-2004, 03:42 PM
  3. computer issues
    By sexualbanana in forum General
    Latest Threads: 04-28-2003, 08:29 AM
  4. Lexus SC300 Issues
    By babyduke in forum Mechanical
    Latest Threads: 01-29-2003, 12:48 AM
  5. legal issues with modifications to the bumper bar?
    By 2000impreza in forum Performance Modifications
    Latest Threads: 09-10-2002, 12:23 PM
