Traction Control on a Honda - Beyond.ca - Car Forums
Results 1 to 6 of 6
Thread: Traction Control on a Honda
    Winnipeg
    Default Traction Control on a Honda
    Hey Guys, how does the TCS work on a Odyssey? Do they use the wheel cylinders and brakes to control slippage at the tires or do they distribute the power through the tranny once slippage is discovered at the wheels?
    oreo cookie
    a wrx.
    if u are talking about an old odyssey, i got the impression that they just cut throttle.
    Nov 2004
    I do believe it uses a clutch driven system, when the rear wheels begin to spin at a different rate then the front, a special silicon liquid inside the diff heats up and sticks to clutch packs inside, transfering power to the rear. I know that this is how Hondas Realtime four wheel drive works, but it might work differently then the odyssey.
    6.7 CUMMINS
    2wd traction control on a honda, wheel slipage is controled by the abs system i thought. It uses speed sensors behind the wheels to sense if one is spining faster than the others, then automatically applies brakes accordingly
    Nov 2004
    hard to say, I thought the odyssey was a van?
    Not Aspen
    Two from Freemont
    This is correct.
    It only works up to 40 km/h
  1. Traction control disable..
    By fast95pony in forum Performance Modifications
    Latest Threads: 05-24-2004, 07:04 PM
  2. 1996 old delta 88 abs and traction control problem
    By jizzdonor in forum Mechanical
    Latest Threads: 05-07-2004, 10:05 AM
  3. 2000 Sunfire Traction Control
    By TAXI34 in forum Mechanical
    Latest Threads: 05-02-2004, 04:58 AM
  4. Racelogic Traction Control
    By Joe Malms in forum General Car/Bike Talk
    Latest Threads: 04-26-2003, 10:06 AM
  5. JDM prelude climate control
    By AutodreamMarvin in forum Mechanical
    Latest Threads: 12-21-2002, 04:35 PM
