BMW E36er's: Relay needed for HID Install? - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: BMW E36er's: Relay needed for HID Install?
    May 2003
    4Runner Trail Edition
    Question BMW E36er's: Relay needed for HID Install?
    I have been reading up on installing HID's with Euro-spec headlights. Some of the instructions I am reading say that they use a relay, but I have been told that it should be fine without one.
    I have all the necessary parts- PNP (Plug n' Play), ballasts etc...
    This question is going out to the BMW guys.
    Are any of you guys using relays for your HID's?
    HELP ME PLEASE
    I am eager to slap these in
    ...searching
    Dunno about relays, but you need Igniters to accompany your ballasts and bulbs....
    Sep 2003
    SW
    E90 M3
    Hey Kaos, what kit are you getting? My XTEC just plugged right in to my factory wiring.......using factory plugs....I am not using a relay I don't think it was just straight plug, stick ballast, play.
    May 2003
    I got a philips H1 kit.
    Plug everything in, crossed my fingers and all I hear is a click.
    Not from the ballast (no misfire)
    I hear it clicking from the fuse box.
    All the fuses are in tact.
    I put in 15 amp fuses where they belonged and still nothing but a click.
    Jun 2003
    Calgary, ab
    Hemi, ZX6R
    Using stock harness's without relays, can damage your stock headlight wiring. I forget, but ballasts draw alot of initial current compared to stock
    You can pick up a set of relays and build it urself. Just get 2 relays, soldering iron, and some extra wire
    Not Aspen
    Two from Freemont
    You should use a relay. The power draw from the HID ballasts will fry you headlight switch over time.
    May 2003
    Thanx for the info guys.
    Ok so now I got it up and running.
    No relay installed.
    My friend is also using the same set-up as me (no relay) and he has had his for about half a year.
    He has'nt experienced problems yet.
    Am I safe for now or am I gonna regret it in the long run?
    Not Aspen
    Two from Freemont
    long run you will regret it.
    You can make your own. It will cost you like $10.
    Here is why you should do it:
    http://faq.auto.light.tripod.com/headlamp-harness.html
    Sep 2003
    SW
    E90 M3
    thanks for the heads up guys, I'm gonna do this over winter break
    May 2003
    Thanx Benyl!!!!
  1. Need help on finding relay on GTS
    By Rock2005 in forum Mechanical
    Latest Threads: 09-09-2004, 08:13 AM
  2. FS: HID Relay harnesses
    By alpha in forum Automotive Parts
    Latest Threads: 08-15-2004, 11:51 PM
  3. Jumper on Pontiac fuel pump relay???
    By Andre63 in forum Mechanical
    Latest Threads: 04-05-2004, 10:08 PM
  4. fs:VW glow plugs / relay MUST SELL
    By ricosuave in forum Automotive Parts
    Latest Threads: 01-26-2004, 01:25 AM
  5. Relay Amperage
    By davidI in forum In Car Entertainment / Electronics
    Latest Threads: 04-06-2003, 09:46 PM
