connecting subwoofer to a 2 channel amp - Beyond.ca - Car Forums
Results 1 to 19 of 19
Thread: connecting subwoofer to a 2 channel amp
    Oct 2002
    Default connecting subwoofer to a 2 channel amp
    how do i do it?? do i connect it to R- and R+ or L- and L+ or a combo?? help?
    2008 Z06
    How many ohms can you run the amp? how many ohms are your speakers rated at? This will decide if you can run parrallel or not.
    Current Cars:
    2004 GMC 2500HD 8.1L
    Past Cars:
    1970 Chevy Blazer, 2wd
    2005 Jeep Wrangler LJ
    1989 5L Mustang
    1990 Jeep Cherokee
    (maah raahde)
    Bridge it instead....
    2008 Z06
    yea, oops
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    Oct 2002
    how do i bridge the amp?? is there a button on the amp or do i do this using the deck?
    (maah raahde)
    You'll have to read the manual on that one.... It's either use R- and L+, or R+ and L-. Basically it involves using on polarity on each channel. Make sure your amp is bridgeable.
    2008 Z06
    It is possible when hooking up more then one speaker to an amp. wiring them in parallel or series makes the difference. Series = more power + harder on the amp.
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    Oct 2002
    ok i found out, its L- and R+, do i put the amp onto High Pass. Low pass, or OFF??
    and what should i set the subwoofer crossover frequency to?
    2008 Z06
    Carefull not to run it at too low a load(ohms).
    freq? what size is it? box spec?
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    Oct 2002
    10" JL 10W3, and it is a ported box....umm...i dont remember the specs....
    2008 Z06
    I'd say set the freq to 60hz. play around w/ it though.
    Current Cars:
    Past Cars:
    1989 5L Mustang
    1990 Jeep Cherokee
    4cyl turbo diesel with a max speed of 10.9kmh
    low pass
    Oct 2002
    Victoria
    Sfire GT and Daytona turbo
    After that display of lack of knowlege, I recommend your nearest stereo shop does the setup for you
    Scott
    CFB Esquimalt/HMCS Protecteur
    Oct 2002
    well...i am here on a forum seeking answers to my questions. I am hoping to learn about things from people who are knowledgable in this field. I want to be able to learn what all the controls do. I am glad there are people like D'z nuts who are actually here to help people in my position instead of people like you who arent helping me in any way at all
    Oct 2002
    Victoria
    Sorry if i was a bit harsh, I would just hate to see you hook it all up and then put it in high pass and fry the sub. Not tryin to be rude.
    Scott
    (maah raahde)
    Of course, you could've just told him the difference
    Basically the difference between low pass and high pass is the frequency the amp is allowed to output to the speaker. Since subwoofers play lower frequencies, the low pass would filter out any higher frequencies the woofer wouldn't be able to play anyways (which could even damage the sub, as Scott mentioned). Similarily, the high pass filters out the lower frequencies and is usually used for speakers, such as components, coaxials, etc.
    Oct 2002
    everything is working good now! thx guys! but my amp isnt powerful enough!! it is a Phoenix Gold QX2180, 180 watts when i bridge it!!! my amp isnt giving enough power to my JL 10w3, can anyone recommend an amp that will power this adequately? for around 200??
    335i
    That is probably not going to power that sub and speakers (If you still have them wired too). Get yourself another sub. With xmas and boxing day coming up, you should be able to get a lower end amp for about $200.
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Oct 2002
    it is just powering my sub now....
  1. subwoofer install help!
    By eur0 in forum In Car Entertainment / Electronics
    Latest Threads: 01-29-2003, 11:48 AM
  2. IRC: Problems connecting to dalnet...
    By nismodrifter in forum General
    Latest Threads: 01-27-2003, 06:06 PM
  3. 4 Channel Amp
    By inspire in forum In Car Entertainment / Electronics
    Latest Threads: 12-19-2002, 04:09 AM
  4. One subwoofer to put in my trunk
    By 5gluder in forum In Car Entertainment / Electronics
    Latest Threads: 12-11-2002, 11:39 PM
  5. WTB: 4 channel amp
    By jaylo in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 08-05-2002, 03:26 AM
