Xbox/PS2 + Projection TV= Bad? - Beyond.ca - Car Forums
Results 1 to 9 of 9
Thread: Xbox/PS2 + Projection TV= Bad?
    Oct 2002
    22 ZR2, 06 YZ250, 77 KZ1000 supercharged
    Default Xbox/PS2 + Projection TV= Bad?
    Now I know on the older projection TV's they say it's bad to play a console on a projection TV because the non moving/non animated items like the spedo, or life bar etc... get burned in the screen.
    But on the new HDTV 1080 ones today are new consoles like the xbox bad for them still?
    I dunno....I read about the same thing years ago, but two of my friends (one with a 52", one with a 60+" projection) have had no problems with their games.
    Aug 2002
    HDTV
    I don't think there should be a problem. Just don't leave the game idle and it should be fine.
    I know you don't smoke weed. I know this. But I'm gonna git you high today. 'cause it's Friday, you ain't got no job, and you ain't got shit to do!
    NOR/CAL
    a nice pair of and1's
    i think rage2 has his hooked up to a projection TV, i used to run mine off my projection TV but then i recently bought an HDTV for my room so i moved my setup down there hahah
    Oct 2002
    Airdrie
    CH9
    It is still the same tecnology as before just with an HD decoder inside you can still have the same problems with the new ones,
    You need to avoid games where the background color remains constant or there are elements that do not change often. On most modern games, this is not an issue.. I have a PS/2 hooked up to my HDTV projection screen and it has been fine.. be careful about hooking up a laptop to the screen, as you may suffer burn in if you use it too much.
    Don't leave it idle for a long time or you can potentially hurt the TV as well..
    Also, on an HDTV, make sure that you switch the games that support it to high definition and 16:9 (assuming the TV is widescreen). Makes a big difference Both games I have that support high definition require a special key combo on bootup, so you will have to check the manual.
    oreo cookie
    a wrx.
    on newer projections, the phosphor wont burn thru for quite awhile....like almost a day....playing for a couple hours wont do any harm
    Calgary, Ab
    So Endurance races on GT3 would be a bad idea then.
    Damn +44411's
    Oct 2002
    with Xbox you just specify it in the setup. It auto recognizes 1080 automatically I think.
  1. Xbox Ghost Recon !!! Brand New !
    By tctdmx in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-28-2003, 04:59 PM
  2. FS:James Bond for Xbox
    By teg_star in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-22-2003, 10:01 PM
  3. WTB: XboX
    By ramminghard in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-21-2003, 02:04 AM
  4. Replies: 11
    Latest Threads: 01-19-2003, 07:59 PM
  5. Cool Xbox Mod
    By mrmattyk in forum General
    Latest Threads: 12-26-2002, 02:10 PM
