Horn Not Working - Beyond.ca - Car Forums
Results 1 to 13 of 13
Thread: Horn Not Working
    Chinatown
    NC1
    Default Horn Not Working
    Well......like the title says......horn not working on the steering wheel......please help the clueless.......new horn? Expensive? Hard to replace?
    Thank you
    Originally posted by rage2
    I am user #49
    Have you checked the fuse?
    335i
    Horns are simple to replace. Two wires going into most. Most likely, your horns wiring has come loose, or your fuse is burnt. Minor job at most.
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    Dec 2002
    A l337 chair
    Do you honk a LOT?
    Chinatown
    NC1
    Ok thank you guys.....no I don't honk a lot......actually I never use it until the other day when I got cut off really really really bad.....then I realized that it doesn't work! haha could be a safety thing man! I can get myself killed if I don't alert other drivers lol
    I am user #49
    Oct 2002
    First find where your horn is and then unplug it. Take a circuit tester or a multimeter (on DC colts) and connect it to the wire going to the horn. (One end to ground the other end to the wire.) Press in the horn switch and if the light comes on or if you get 12 Volts on your multimeter the horn is bad. If you get nothing the wiring or the horn switch is bad.
    9.872604, -85.498802
    Turbos n Stuff™
    Oh man OH MAN...I cant go a day without a good ole hornhonk.
    There is a connector between the wheel and the hub, make sure thats not interrupted at all. Check the fuse as well as mentioned above.
    Travel
    Jul 2002
    E90 335i
    Just get that bumper sticker that says "Horn not working - watch for finger!".
    George likes his Kung Pao spicy!
    Aug 2002
    oreo cookie
    a wrx.
    thats german reliability for ya
    Jul 2002
    '15 GTI
    haha, german cars just get rid of whatever they dont need, theyre intelligent that way, max's car just figured "hey he never uses the horn, i might as well disable it"...same thing happened to my fuel pump
    Sep 2002
    CSpot
    11 sec weather van
    Originally posted by mrmattyk
    Do you honk a LOT?
    LOL
    Most horn are grounded through the body on the cars ive worked on. Ground horn to battery- supply power= honk
    Turbos n Stuff™
    Whos car is broken right now? and whos car drove you all over the place?
    Travel
  1. Replies: 4
    Latest Threads: 12-09-2002, 12:16 AM
  2. Vtec is not working
    By Dirty_SOHC in forum Mechanical
    Latest Threads: 10-20-2002, 11:26 PM
  3. Horns not working on Sparco Steering Wheel...
    By AaronS13 in forum Mechanical
    Latest Threads: 09-17-2002, 12:26 AM
