Well......like the title says......horn not working on the steering wheel......please help the clueless.......new horn? Expensive? Hard to replace?
Thank you
Thank you
I am user #49Originally posted by rage2
Shit, there's only 49 users here, I doubt we'll even break 100
Have you checked the fuse?
Horns are simple to replace. Two wires going into most. Most likely, your horns wiring has come loose, or your fuse is burnt. Minor job at most.
Original Post NAZI Moderated
Originally posted by r3cc0s
Felon or Mistermeiner
Do you honk a LOT?
Ok thank you guys.....no I don't honk a lot......actually I never use it until the other day when I got cut off really really really bad.....then I realized that it doesn't work! haha could be a safety thing man! I can get myself killed if I don't alert other drivers lol
First find where your horn is and then unplug it. Take a circuit tester or a multimeter (on DC colts) and connect it to the wire going to the horn. (One end to ground the other end to the wire.) Press in the horn switch and if the light comes on or if you get 12 Volts on your multimeter the horn is bad. If you get nothing the wiring or the horn switch is bad.
Oh man OH MAN...I cant go a day without a good ole hornhonk.
There is a connector between the wheel and the hub, make sure thats not interrupted at all. Check the fuse as well as mentioned above.
Travel
Just get that bumper sticker that says "Horn not working - watch for finger!".
George likes his Kung Pao spicy!
thats german reliability for ya
haha, german cars just get rid of whatever they dont need, theyre intelligent that way, max's car just figured "hey he never uses the horn, i might as well disable it"...same thing happened to my fuel pump
LOLOriginally posted by mrmattyk
Do you honk a LOT?
Most horn are grounded through the body on the cars ive worked on. Ground horn to battery- supply power= honk
Whos car is broken right now? and whos car drove you all over the place?
Travel
