I do have a manual. I am away from my computer right now.
Will send you a reply with manual when I return.
Thanks,
Gary.
Thanks,
Gary.
Hi Gary, I'm just checking back with you Have you had any luck locating the manual for the cs310i? I
Tim
I hope you still have the manual... I'm still looking for one...
I am new to any forum so i will apologize in advance for any etiquette foopas. Bin surfing for any info on command start, programming fobs. I did the hood pin twice, press the #1 button and all is fine now, thanks by the way. To start I have to press both buttons, I guess that would be normal, maybe safety issue not sure. Can I reprogram the transmitter to start with only pressing the #2 button? So many questions. Replacement transmitters still available? The door locks on the right side seem to stick when using the fob, relay, connection issue? 1995 4runner. I have more but lets start there. Appreciate any info you may have. This is a 275i model command start.
Thanks in advance.
The CS275i is setup that way.
Sounds like you need a double pulse unlock, which can be changed in the programming.
Well, That explains the 2 button start. Makes sense to lessen the chance of an accidental start. Would you have the instructions to do the double pulse reprogram. Wife did notice the locks on the right occasionally would stick with the drivers control so probably the command start isn't the real issue.
Thanks again
Dale.
I'm looking for a programming guide for model 270i. I purchased a replacement remote, and seem to have misplaced the manual. Would it be possible someone has it?
My e-mail address is [email protected]
- Topher
On its way
If anyone has any manuals for cs310i command stRt with 4button red remote, can they please send to me. [email protected] my car battery went dead and it lost its programming. Now the auto door openers don't work. Ithink they trigger the wrong power rail now. They need pos not neg. remote infor and programming guide needed. I dont know what is button one or two to program, and what the program sequence is. Thanks
I looking for the installation and programing manual for what I believe i the Command Start 320i with a two button remote. Any assistance would be greatly appreciated. My Email is [email protected].
