Low comp or high comp pistons with a turbo
I said you should use lose compression pistons for turbo. Some guy said you should use high compression pistons:
"thats pretty low for an allmotor honda.
this guy wants around 250whp with a turbo. now if you werent living with 1982 turbo knowledge you would agree that higher compression will net him more power for every pound of boost he is running, and lead to much better response, better off-boost performance, and less lag.
our cars are already low compression, if he runs a gt28rs with 10 or 10.5:1 compression he will have a much better running car than 8.5:1.
if he needs the safety net of lower compression if he wants a ton of useless fwd hp then go with 8.5:1. but if he's building his motor for lower power applications and a nice fast street setup, then going with an allmotor style build will net him better results.
turning car into fireball at 10:1 ? what a joke. i guess all of those turbo celicas and itr's on stock motors and turning into fireballs left right and centre...."
2002 Nissan Sentra Spec-V: AEM, UR, HS, Greddy, G2, MTX, Grafxworks, Eurolite, Sprint, TWM, MOMO, Mobil 1, ES, SenDel, Toyo, DieHard, Sylvania, 20% tint, Alpine, Clarion, Redline
