Jetsgo does a little "grass-cutting" at YYC.. - Beyond.ca - Car Forums
Results 1 to 17 of 17
Thread: Jetsgo does a little "grass-cutting" at YYC..
    Dec 2002
    2002 SVT Focus
    Exclamation Jetsgo does a little "grass-cutting" at YYC..
    This happened on Thursday 20 Jan .
    Anyone work this flight ?? How bad was the damage ??
    NATIONAL POST
    01/25/2005
    Federal investigators are trying to determine why a Jetsgo flight with 78 passengers aboard suddenly veered off the runway at Calgary airport last week, trundled along the grass verge, then took off again from the turf.
    As it tore 1,600 feet along the frozen ground, the McDonnell Douglas MD83 ran over a sign, apparently damaging flaps, landing gear doors and hydraulics, according to an official report on the incident.
    The incident began just before 8 p.m. Calgary time last Thursday, as Flight 191 from Toronto touched down on Runway 34, according to a report on Transport Canada's Civil Aviation Daily Occurrence Reporting System (CADORS), obtained by the National Post.
    Crew members reported they felt the aircraft start to slide off the runway, so elected to do a missed approach, meaning they would lift off and try another landing, said the report. The crew told the control tower they had to get back to ground as soon as possible because of what they called a "fuel emergency."
    The plane landed safely again at 8:10 p.m., with no injuries reported.
    11 F-150 Supercrew FX4 5.0
    Nov 2004
    MB C63
    so it took off regardless of all the damage caused?
    jetsgo is really going down the drain
    i have a flight december 21...delayed it 10 hours spent the whole day at the airport cuz they didnt even know what was going on.
    Apr 2003
    Vancouver
    2010 GLK350 4MATIC, 2006 SLK350
    Maybe is slid or something on the frozen ground? But I can't believe they still took off after all the damage!
    Dec 2002
    2002 SVT Focus
    Sorry , I cut off too much of the article (now edited better..) .
    The flight was landing,veered off the runway,and conducted a missed approach .
    calgree.
    Impreza
    ahhh flying, the illusion of safety.
    Apr 2004
    Cochrane, AB
    purple people eater
    sorry guy but flying is far, far, far safer then driving. I suppose most of the image it has as being unsafe comes from either the complete lack of control passengers have (I dunno about you but not being able to prevent an accident or escape or something makes me uneasy) or the tendency for everybody on the plane to die when it crashes. but maybe two planes crash per year out of millions of flights, while thousands and thousands of people are killed in motor vehicle accidents every year.
    a lot of this has to do with the media - a plane crash will get international exposure, while a car crash will get local, maybe provincial coverage.
    Feb 2003
    L-Tuned
    Phew, glad I never fly Jetsgo!
    Jul 2002
    Yeah i've probably been on about 5 or 6 jetsgo flights and only one has left on time. The others all 1-4 hrs delayed.
    bmw m3
    Shit man scarey shit . I think the worse would be just landing in the middle of the ocean.
    Flying makes me uncomfortable cause i cant control it.
    AFAIK CFRYH is still there awaiting or recieving repair. Funny how it took the press 4 days to catch this one.
    From what I've heard:
    - wx was 1/2sm in fog, 400 overcast, 1400ft rvr
    - runway was reported as bare and dry, but the wind was out of the east and the aircraft slid off to the west...
    - intial reports had the plane landing half on/half off the runway as it seemed the crew thought there was runway centerline lights, tore through the grass/snow, took out the RW25 hold short sign and proceeded into the missed approach, although apparently there are skidmarks trailing off the edge of 34 and then parralleling it for some 1600ft or so before they became airborn again at/past 25.
    - the fuel emergency was declared so as to give them priority sequencing as there were several other aircraft waiting to land.
    Thankfully no one was injured.
    9.872604, -85.498802
    Turbos n Stuff™
    For those naive to think this happened just because it's "jetsgo" are fooling themeselves. All airlines follow all the same exact procedures and have to obey all the same guidelines. Could have happened to any airline. This time around it just happened to happen to one most people dislike. The Pilots flying these aircraft are I'm sure just as good as any other airline. They all have their good and bad days.
    Travel
    Not Aspen
    Two from Freemont
    yes and no.
    All airlines have to follow the same guidlines, but don't kid yourself into believing they all follow them equally. Many cut corners. History shows us that it is typically the smaller start up airlines like Jetsgo that cut corners on everything from safety to the crappy food (or sometimes lack there of).
    That is not to say that Large airlines do not fall in the same category (United being one that comes to mind).
    Dec 2002
    CGY
    94' Terd
    I personally didn't see the damage, but our company brought the flight in. Some guys said that the underside of the wing between the #2 engine and the fusalage was quite badly damaged. They took out a sign that pretty much destroyed the rear flaps and dented up the plane pretty bad. The thing that I don't understand is that the pilots even though the landing gear hydraulics had been damaged, retracted it once they bounce off the "runway". If the hydraulics had been damaged bad enough they wouldn't have been able to lower the main gear again, forcing them to land on the belly of the plane. Pretty amatuer move if you ask me.
    To to give you and idea of how retarded Jetsgo is. They let the pilots (with no passengers of course) fly the plane to Winnepeg on Sunday without any repairs being done. It was being refueled and serviced in Winnepeg then flown to Toronto to be repaired.
    From what I heard the plane didn't even touch the runway on the first landing attempt. It landed off to the side of the runway in the grass, hit the sign and bounced back into the air. Pretty fucking sketchy if you ask me.
    ...searching
    Boo with Jestsgo, made my 3 hour lay-over in T.O turn into a 7 hr lay-over. Plus the fuckers kept switching our departure gates (4 times) because their heads were lodged in their asses..
    Jetsgo
    Originally posted by benyl
    yes and no.
    This isn't the first incident for JetsGo. They seem to be inching ever closer to disaster.
    ecstasy_civic's Avatar
    ecstasy_civic is offline MMA guru, but still rage2's bitch
    Aug 2002
    08 Si
    Well, as Dubbed said, it was our company that brought the plane in, I was there the next morning.
    It did not travel until 3 days after the incident.
    My dad is also the captain @ the airport firehall who followed the plane down the runway after the second landing attempt. so I got his side of it too.
    I work the Jetsgo flights everyday and yes they have a HORRIBLE track record for being on time, and they do take short cuts. That plane RYH did leave without having the repairs fixed, there were some things that needed to be addressed before take off, but maitenence seemed to think it was worthy of the trip, the few parts that were replaced here made it "safe" but.......... regardless it fairied out and made it safe, that same plane is coming back to YYC tommorow afternoon I believe.
    The funny thing was, I had breakfast with the Jetsgo supervisor the other morning and a reporter/media person was on the arrivals level asking what happend with the emergency landing, apparently he heard it on a scanner? and out of ALL the people who were either on the flight or worked the flight, had no idea whatsoever what had gone on.
    Some passengers even said they just thought it was a rough landing which I find hard to believe
    Personally I dont like jetsgo, they are old planes that constantly need maitnence and with there new schedules I really see it hard to make any money when you have between 5-10 people on a 160 passanger plane
    Ive got tons of Jetsgo stories if someone wants to compare
    Jul 2002
    Stupid airline, I flew with them once, felt unsafe both ways, never again, Westjet all the way. Maybe being an aircraft mechanic has something to do with it, either way, they suck.
    And why is every flight attendant french btw?
  1. Those little little bikes??
    By SleeperD in forum Bike Talk
    Latest Threads: 11-03-2004, 11:51 AM
  2. YYC peeps
    By 5.9 R/T in forum General
    Latest Threads: 10-08-2004, 05:55 PM
  3. YVR to YYC
    By benyl in forum Misc. Gallery
    Latest Threads: 02-10-2004, 11:48 AM
  4. Cheapest place to order SOD/grass from?
    By Hollywood in forum General
    Latest Threads: 03-24-2003, 07:41 PM
