http://www.imagestation.com/album/pi...707625&start=1
I had a good time too. Comptech SC S2000......yes please.
My runs were so bad. I was all over the place. I had one DNF, and I plowed over a bunch of cones in the same spot twice. Oh well, it's all learning.
My best time was a 53.255 + a cone. I had Fluid_Digital as a passenger on that run and my lines were majorly sloppy. On the last run (#5 oops), I drove a lot cleaner. Fluid_D was still in the car and I bet that last run was at least 1.5sec faster then the previous, but they wouldn't give me my time because I wasn't supposed to have a 5th run.
BTW my car only has I/E. I really want to upgrade my suspension.
Oh, after the first slolom bit I was 1/2 way through 3rd gear and entering a fast 80 degree right then a 110 degree left. Through the right hand turn, I let off the gas and the tail got loose to the left. I was counter steering as the tail shot to the right from over compensation. Luckely I was now pointed at the big left hand turn but the tail was still wanting to go to the right. So for about 100 of the 110 degrees of the left turn, the tail was drifting to the right as I steered into it in 3rd gear and the throttle mashed. Everything worked out ok and I was in partial control. I was alone in the car both times this happend but the other time wasn't such a swing from drift to drift. I tried to repeat it w/ Fluid_D in the car, but it wouldn't work. Super fun.
ps. Fluid_Digital, I thought you were going to show me your tail lights at that last intersection. Maybe next time....Aaahaha
