3rd gear grinding.... - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: 3rd gear grinding....
    Jul 2002
    93 Prelude SR-V
    Default 3rd gear grinding....
    My 3rd gear grinds, alot... Its starting to worry me, and causes me problems when I shift hard..... Is there anything I can do.... Im looking at just buying a new tranny and putting it on, unless I can somehow adjust it..... Im pretty sure its the synchros, but it might not be....
    Any suggestions.
    Aug 2002
    Oct 2002
    05 GDB V.8 / ZX10R / T1-7L
    Default Re: 3rd gear grinding....
    Any suggestions.
    Double Clutch(derpress the Clutch twice before throwing it into third) other than that you have a worn Syncro and it would Probably Better to get a used Tranny than Getting it fixed, if this is for a honda Acura, instead of getting the Same tranny, try and find one with Shorter Gears
    Originally posted by kaput
    I have the same problem with reverse. About half the time when I try and get it in there it grinds, and scares the shit out of me for no good reason. It feels like it's not aligned properly or something because when it does get in, it shifts rather nicely, but when it misses, the grinding starts when the stick is only about halfway to where it fully engages almost like its grinding something else?? Or maybe that's normal, I don't know anything about trannys.
    Try putting it into third before your throw it into Reverse this Ussaly stops the tranny and Alings the reV mesh sos that it wont Grind, other than that change the tranny it comes out to be cheaper than repairing it and Tranny swaps are easy to do, so you shouldnt have to spend a dime on Labour
    Jul 2002
    93 Prelude SR-V
    Double clutching doesn't help......
    Dec 2002
    Calgary,AB
    A Pearl Diamond
    I was told that prelude transmissions are really strong. I used to have a mr2 and that grinded in 3rd too. I hated it, i could'nt have any fun with the car cause everytime i shifted fast it seemed like i was breaking something. I know how it feels to have a grinding tranny and it sucks! Sorry to hear about that.
    Aug 2002
    Canada
    DUBZ
    gg
    9.872604, -85.498802
    Turbos n Stuff™
    make sure your syncros are okay and check to make sure your shift linkage is good and secure.
    I had grind on my reverse and first gear (Euro cars have reverse left and forward just like first) and it turned out to be a beaten ball joint on the shift linkage. Now it shifts premium!
    Travel
    Jul 2002
    93 Prelude SR-V
    Ya it seems to like actually shift fine, its just getting it into the gear, it sounds ilke i grind it. Or the actual shifter vibratates a bit.
    Cochrane
    Is'nt there some kind of special transmission oil that is supposed to stop grinding in the gear box ??
    I'll see if i can find out what it's called
    Dec 2002
    Calgary,AB
    A Pearl Diamond
    syncro mesh it the name
    Cochrane
    Redline MT-90
    try it out i have heard mant good things about it
    '08 Mitsubishi Lancer, '97 GMC Jimmy
    I have been having this problem recently with my car,( '86 MR2) i CANNOT shift into third above 6000 rpm or it grinds and will not go into gear.....kinda sucks. (7500 rpm Redline)
    oreo cookie
    a wrx.
    dude, your car redlines at 7700rpm...fuck the tach!
    anyway, i sometimes grind into reverse before the car warms up...
    Oct 2002
    Oh right another comon Proble with Gear Grinding is Low Oil Level in the tranny, or it migh tjust be old and dirt and needs to be changed out
    Jul 2002
    93 Prelude SR-V
    When I rebuilt my engine I drained the entire tranny system and put new oil in.
    The Gutter
    UCF20/R35
    Could be from abuse by the previous owner
    Originally posted by rage2
    Dec 2002
    A l337 chair
    While we're on the topic of manual transmissions...
    Is hydro assisted as good as people say it is?
    a dumpster some where in the city
    SKYLINE GTR ,AE86, memories of a turbo 2000 lude
    i have this problem with my 3rd gen winterbeater all the time. change your transmission fluid,but make sure you use honda manual transimisson fluid. and try not to use synthetic motor oil if possible cause motor oil does not contain the proper additives,continued use with motor oil can cause stiffer shifting.
    that is actually a common problem among 4th gen ludes.
    I had a bad 5th gear grind when I had my 4th gen, and according to the Lemon book, it says tranny grinds are pretty common
    oreo cookie
    a wrx.
    mismanufactured shift fork in 4th gen ludes
  1. For Sale - 3RD Gen RX-7 with 32,000kms!!
    By cya in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 09-26-2002, 07:50 PM
  2. 1/4 mile gear changing
    By HOK in forum General Car/Bike Talk
    Latest Threads: 07-11-2002, 08:53 AM
  3. 3rd prize from Quinn
    By sexualbanana in forum General Car/Bike Talk
    Latest Threads: 07-05-2002, 11:00 PM
  4. July 3rd Solo2 Pics
    By Davan in forum Cars, Bikes, Machines
    Latest Threads: 07-04-2002, 10:34 PM
  5. Swapping into a 3rd Gen Lude
    Latest Threads: 06-27-2002, 09:28 PM
