10g's eh? if i only had 10G's in my back pocket
That was my thought at the time I pulled out my wallet and it started sobbingOriginally posted by 2000impreza
I think reg is in germany right now.....
This is my personal opinion, reg is the man for toyota and maybe some BMW stuff but he does not know jack about hondas. For the most part he has done alot of work on tien's turbo teg and that thing is a total dog (sorry tien if you are reading this but it "was" true, I hope your new setup is better) And tien's car got half way respectable when he took in hongcouver for some more tuning.
I would look else were if i was all of you with hondas.
im only running stock injectors and stock pump,but i have 2 440cc sub injectors at the intake and the earls mf2 unit that tells the injectors start spraying when it reads boost.Originally posted by redline
The AEM is more of a true standalone vs the hondata. The base maps are not that good and you will have trouble getting the car to run. Some people on other boards have spent like 10 hours just trying to get the car to start with an AEM unit. I wish you luck with that project. Make sure you got a good laptop and a lot of patinence and make sure you can be without your car for a few days.
How big of injectors are you going to run?
good luck with your project.
I do not see the point if you are going to run stock injectors. You must run bigger injectors to take full advantage of a AEM or Hondata. I would start with 550cc injectors and move up from there as you need more fuel.
lovely, so i picked the wrong part to get first, oh well at least i will have the aem for later; until i can afford the injectors which will probably be next year, lol.but still won't it at least help out with my fuel and timing a little better than it's running right now????i know i need a fuel pump, bigger injectors, and maybe a fuel rail. But i also could use a million dollars,12 preludes, one for every month of the year, and parents to support me.
well injectors is only $700 for brand new RCs 550cc and the AEM will work good once it is tuned up!
