solar panel battery charger - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: solar panel battery charger
    Airdrie/Calgary
    Default solar panel battery charger
    i was just wondering if anyone owns or has tried the solar panel thing from canadian tire CLICK
    just wondering if it actually works and if its worth buying.
    Nov 2004
    MB C63
    Link doesnt work cuz it asks for postal code
    http://www.canadiantire.ca/assortmen...romSearch=true
    Copy and paste that into your browsers...i hope thats the right one. If it is then its worth it if you dont want to buy a battery charger for your car. If you want to try it buy it try and if you dont like it return it
    Nov 2004
    MA
    Infiniti
    No more dead car batteries! Plug the 1.8W Solar Battery Charger into your vehicle's 12V outlet and use it to protect against key-off electronic drain and extreme cold-weather effects.
    Ideal for car batteries
    Not designed for outdoor use
    Works under most light conditions
    Ensures quick starts and extends battery life
    Connects in seconds through 12V outlet or direct-to-battery
    Built-in blocking diode prevents key-off electronic drain
    Manufacturer's limited 5-year warranty on power output
    i guess there is two
    Eliminator Solar power panels are an easy-to-use, guaranteed solution to an ever-growing need for alternate power sources or backup power
    Panels convert sunlight, even in low light conditions, into 12 V electricity - ideal for charging all types of vehicle batteries and power packs
    Works well with small cars and appliances
    Extends battery life, reduces expenses of replacement
    Includes quick-connect hardware: connecting wire, DC clips, 12 V socket plug and barrel plug, mounting hardware/accessories
    Built-in reverse current protection; won't deplete the power-supply system
    sounds a tad shady, in all actuallity, i think it will be like the tornado, if you believe it works, it will work, only because you cant see past your own beliefs...i think
    well a way to test this is to use a car with a dead battery. plug it in, leave it there for a week then try to start it
    Apr 2003
    Don't think it's total snake oil as new VWs come with those from the factory when they arrive at the dealer to prevent a dead battery I guess. Plug into the cig lighter and sit on the dash.
    Khyron
    Airdrie/Calgary
    ya i figure ill give it a try, its only like $23 and if it dosent work that well i can just return it
    May 2004
    Low Rent
    If people ask you what the heck it's for, tell 'em you've got solar-powered headlights.
    "Oh yeah! Plus, armed men are stealing my pop!"
    Bicycle
    It may aid an old battery but if you have problem starting the thing, you probably should look at a new battery instead of this.
    But it's probably usuful on camping trip when your better half draing the battery using her hair dryer.
    Airdrie/Calgary
    ya i was going to get so that i could run my stereo without having the car on,
    Aug 2004
    Don't think you can run a strereo on it.
    It works more like a trickle charger to provide a small constant charge to the battery during extended periods of storage.
    I have one on my trailer battery right now in the garage.
    Remember, Its only rated for 1.8 watts.
    At 12 VDC thats only .15 of an amp.
    Hardly enough to run anything useful.
    Just FYI.
    2011 Ram 1500 QC Sport
    2017 Jeep Cherokee Limited
  1. Solar Pannel Question
    By Stine in forum Computers, Consoles, and other Electronics
    Latest Threads: 11-06-2004, 06:43 PM
  2. FS: BlueMate Bluetooth Headset w/ Charger & Car Charger
    By j0nblayz in forum Cellular Products
    Latest Threads: 09-28-2004, 10:28 AM
  3. Replies: 6
    Latest Threads: 09-28-2003, 08:37 PM
  4. Solar system similar to ours found
    By Dope Dealer in forum General
    Latest Threads: 07-04-2003, 08:24 PM
  5. Solar Eclipse June 10
    By bol in forum General
    Latest Threads: 06-06-2002, 08:49 AM
