Cleaning Headlights - Beyond.ca - Car Forums
Results 1 to 15 of 15
Thread: Cleaning Headlights
    Dec 2004
    TSX
    Default Cleaning Headlights
    What product is good to use to make you headlights look like new again?
    btw, they're plastic.
    i've heard of wetsanding but i don't really want to do that. I just want something that you can spray then wipe.
    Apr 2004
    Cochrane, AB
    purple people eater
    do it the right way or it won't last.... wetsand.
    Dec 2004
    Banff, Alberta
    525it/XC90/V70R
    what grit do you use? i believe you have to keep doing it every so often as they tend to go foggy. no big deal though
    Dec 2004
    YYC and YVR
    GSE36, GGL15, GSE25, CBR600RR
    i used 600, 1200 and 1500 then use Meguires PlastiX to clean and polish. I was worried at first but the end results...definately worth it
    Apr 2004
    Cochrane, AB
    purple people eater
    if they keep getting foggy you need to take the headlight apart and re-do the bead of sealing that runs all along the lense. it's different for every car but the basic idea is that you take your headlights out, remove the bulbs and all the metal clips holding the lense on, put it on the oven at a moderately hot temp. like 200-225 for a few minutes and then you should be able to just pry the lense off. clean it out, paint the housing black or something cool like that, and then using silicone sealer from crappy tire to seal it all back up again.
    Apr 2003
    '99.5 2.0L Jetta What I ride: '05 Kona Stuff
    I used the Meguire's PlastX just the other day on mine, but it didn't do that much.
    However I read in another post that you really have to use a lot of elbow grease, so I guess I'll give 'er another go when I get a chance.
    Dec 2004
    TSX
    then can someone exactly explain to me the process of wetsanding?
    Apr 2003
    I searched for a few links that could explain the directions as I have never done it myself:
    http://www.autobodystore.com/cgi-bin...mes%3Bread=887
    http://woodstore.woodmall.com/weba.html <- If you want to pay money
    http://forums.beyond.ca/showthread.p...threadid=58633
    I'll let you put it all together!
    Jun 2004
    90 DB1, 03 RL1, 07 YK1
    This should work for pretty much any vehicle with plastic lenses. I did this last summer and they look fantastic. It mainly depends on what condition you headlights are to begin with. The method described here is if they are really bad and yellow. Just skip certain levels of sanding depending on your situation.
    wet sanding headlights
    May 2004
    Calgary , Alberta
    2008 Toyota Tundra
    if your headlights are just dirty and the outsides are hazed, just get some toothpaste and rub it into the headlights, let it set a minute, then get a cloth and wipe off the tootepaste and whooola all clean
    Dec 2004
    TSX
    for this meguirs plastix thing, do i need to also buy that special cloth? i used it and it only helped abit
    Jan 2003
    02 Accord
    WTF? Toothpaste... Does it give that nice blueish/purple color when the lights hit the lense?
    May 2004
    Calgary , Alberta
    2008 Toyota Tundra
    no just use some whitening toothpaste, i did it to my integra a few months ago when they had hazed abit on the outside due to the weather, cleans the outside real good.
    Apr 2003
    Yeah I used it once and it didn't really do too much. I think the key might be to use some serious elbow grease with it. I just used a clean cotton cloth, next time I'll crank it up a notch and see if I can do a little better.
    Feb 2005
    the best and easiest thing u can do if u r getting ur car repainted...
    get the painter to scrub ur headlights and ur tail lights like the way they do to the old paint
    and then spray some clear coat....probably 2-3 coats will do
    and u'll lights will shine as new !...
    lol..
  1. Cleaning Out Sale
    By CrAzY_PLaYa in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 05-03-2003, 09:48 AM
  2. wtb: aem filter cleaning system
    By Seks in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 02-25-2003, 01:39 PM
  3. cleaning puke
    By Lo)2enz0 in forum General Car/Bike Talk
    Latest Threads: 01-12-2003, 05:17 AM
  4. FS: GEN5 Prelude Parts..cleaning out the garage.
    By VTEXTC in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-30-2002, 12:53 PM
  5. Cleaning the engine bay
    By Rydog in forum General Car/Bike Talk
    Latest Threads: 06-27-2002, 08:30 PM
