anyone know an easy way to get the gum from a sticker off a window? the previous owner of my car had some sort of sticker on lower left windsheild and there's the damn glue/gum still there.
thanks
thanks
HEY, AT LEAST I OWN IT
Goo Gone, crappy tire has it for under $5
or spray WD40 on it and let it sit, or heat it up with a heatgun
A flat razor blade works well. Just get the glass wet and scrape the razor across it. Just watch out for the defroster lines on rear windows. If you break them, you'll have to repair it or that line won't heat up.
Methyl Alcohol works very well and evaporates when your done
Some People Are Like Slinkies, No Matter How Many Times You Push Them Down The Stairs, They'll Always Put A Smile On Your Face.
i'll try the razor idea, but it's in a real tricky spot down there........worth a try anyways...
what's methyl alcohol? or what household item might it be found in......someone pm'd me to try gasline antifreeze? n e one ever heard of that method
gasoline works but it stinks, just get goo gone its good.
acetone works too. Great for removing decals and pinstriping. But if you get it on your paint you'll have to buff and polish that area. It removes the shine.
goo gone it is, thanks
