Wiring an amp - Beyond.ca - Car Forums
Results 1 to 3 of 3
Thread: Wiring an amp
    2018 Ford F150 SCREW
    Default Wiring an amp
    i have a friend that wants me to install a sub and amp for him. He has the wiring lit and everything. He is running the stock deck though. This means that instead of using rca's i run speaker wire from both of the rear speakers to the amp right. There is also a kenwood cd changer inthe back, should i run the remote wire to that or the back of the factory unit.(wire colours would be great). And finally is there allready a hole that the power wire can run through or do i have to drill one? where is the best spot. only 8ga wire. It is going in a 98 gmc jimmy. any help would be great.
    thanks
    matt
    9.872604, -85.498802
    Turbos n Stuff™
    You can use the premade holes in the firewall, if the wire will fit through the prefasioned gromet.
    I'm not so sure on the deck its self...remote wires are generally blue. If the stock deck would have one though, I'm not sure.
    Travel
    4cyl turbo diesel with a max speed of 10.9kmh
    Default Re: Wiring an amp
    thanks
    matt
    hey man, my amp is wired through my front door speakers, for the ground, fold over one of the back seats, lift up that panel, and put the ground onto a piece of metal under there, the remote wire could be found on the back of the deck, its just a blue one, u will find a hole for the power wire if u pull back the floor mat on the passenger side.
  1. Does anyone need amp/subs wiring or a cap?
    By JJLuke in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 01-03-2003, 02:01 AM
  2. wiring power
    By ramminghard in forum In Car Entertainment / Electronics
    Latest Threads: 11-29-2002, 07:47 PM
  3. Amp wiring kits
    By silverEL in forum Miscellaneous Buy/Sell/Trade
    Latest Threads: 11-28-2002, 06:38 PM
  4. Sub/Amp wiring kits
    By dj_honda in forum In Car Entertainment / Electronics
    Latest Threads: 10-20-2002, 09:05 PM
  5. wiring
    By redline_13000 in forum In Car Entertainment / Electronics
    Latest Threads: 08-15-2002, 08:23 AM
