Anyone know where I can get some plexiglass? - Beyond.ca - Car Forums
Results 1 to 20 of 21
Thread: Anyone know where I can get some plexiglass?
    335i
    Default Anyone know where I can get some plexiglass?
    I need some plexiglass for a little project. I also need it to be cut, or suggestions for making a perfectly straight cut.
    Original Post NAZI Moderated
    Originally posted by r3cc0s
    Felon or Mistermeiner
    '08 Mitsubishi Lancer, '97 GMC Jimmy
    Home Depot Maybe? ....i need some plexiglass pretty soon here too, for a little project for my Car.
    2008 Honda Civic
    homedepot has it, use a dremel to cut out circular shapes its pretty easy, then just sand down the rough edges...u can use a saw to cut straight lines
    Some glass shops carry it, you can also ask them to cut it to a specific dimension.
    335i
    I need some thicker stuff, not the mm crap. Around 1/2 inch or so. I'll call around the glass shops today. Thanks.
    Oct 2002
    Airdrie
    CH9
    Go to Acrylic Concepts in the NE chaepest place in town. I use them for all the time for work
    Aug 2002
    Toronto
    2009 STi
    Industrial Plastics and Paint too (south)...
    Dec 2002
    Gainesville, FL and West Palm Beach, FL
    2002 Accord SE Coupe
    Home Depot.
    I use them for projects and stuff for friends' cars, my art, etc.
    Sep 2002
    CGY
    Cayman, F150, Crosstour
    Revy, or Home Depot.
    335i
    I'm looking for some thicker stuff. The ones I remember at Ace and Home Depot are millimeters thick. The one's im talking about need to be about 1/2 inch or 3/8 at least
    Yeah these guys are awesome...they are located at 1420 40th Ave NE...phone (403) 974-3240
    Does anyone know if anywhere that sells plexiglass will actually cut it to the Size you need? i only need 18" x 18" at the most, and the sheets they sell at Home Depot/Revy are like 36" x 48", and they dont cut it down to size, you have to buy the whole sheet and there like $30 and up, so i only need like $10 worth of the stuff.....I'll try that acrylic concepts i guess tomorrow.
    Jul 2002
    industrial paint and plastic on 2nd street and 55 ave SE has it.
    Don't know what size it comes in, I think they can cut it as well.
    Aug 2002
    orange county
    PRV
    I'm not sure if the Home Depots are different near you, but the local one DOES sell 1/4 to 1/2 inch plexi & lexan. You have to buy certain sizes, but usually they offer a good selection.
    I found that lexan is usually better (even tho its harder to cut) because plexi scratches SO easily!
    My question is: Where do you go to get the stuff "shaped" (heated so that it is curved)? I tried shaping a sheet with a heat gun... the stuff wouldn't budge
    Green, GREEEEEN!!!
    Dec 2002
    350Z
    what are you planning to use it for?
    I just need it for a Rain Sheild for my intake( hood has vents)
    Jan 2003
    Edmonton, AB
    2010 Genesis Coupe
    thick plexi is very very expensive.
    cutting is easy enough if you can handle a jigsaw and follow a line, just use bimetal blades, they go through plexi like a hot knife thro snow.
    heating... good luck, lmao, the thicker it is, the longer its going to take for heat to soften it.
    sorry, shouldnt laugh, but i have some old memories.
    get a tub of water and put the plexi in there, then fill it with boiling water.
    or put the plexi in a low heat oven.
    you will likely be able to bend it, but itll probably have waves and distortion out the ass, so if you plan on being able to see through it, revise those plans.
    if you wanna post exactly what you need to do, i can probably help you figure out a way to do it, or suggest a different plan of approach.
    Sep 2002
    CGY
    You should be able to shape it in the oven on low heat.
    I made a "plexiglass" signal light lens for my celica a while back until I could find one to replace it. (left it on for about 2 years... ) Heated the plexiglass in the oven on low heat, then removed it (w/oven mitts) and then rolled it over a ball (I actually used a large orange...ghetto style..) while it was still hot to give it the shape I wanted. Worked great....and you could still see through it and no distortion.
    Then held it in position until it cooled...
    Found the directions on how to make it on some "toyota paseo" site, on how to make clear corners for the car....
    Aug 2002
    MDX
    shape it, then maybe chuck it in some cool water???
    Jul 2002
    use carbonfiber / fiberglass / and some foam
    easy to do and looks good.
    of course if you want the see-through part this isn't gonna work, but for james's intake 'hood' it should be easy.
  1. Replies: 1
    Latest Threads: 02-24-2003, 10:50 AM
  2. Can I get some feedback please!!
    By Importz in forum General Car/Bike Talk
    Latest Threads: 02-11-2003, 04:22 PM
  3. Replies: 2
    Latest Threads: 11-26-2002, 10:47 AM
  4. Anyone know a good engine i can put in my tiburon??
    By tibby2000 in forum Performance Modifications
    Latest Threads: 11-23-2002, 12:58 AM
  5. Anyone know how to get to St. Paul AB?
    By three.eighteen. in forum General
    Latest Threads: 11-08-2002, 09:59 PM
