has any one had this problem before, the boost in first gear is significatly lower than the boost in third? Actually, when I'm in first gear and second gear, I boost about 1-3 in first and then when I shift to second, I can usually get 4-5 and from there on, I can boost my full 6-7 psi. Why is this happening? I have an internally set wastegate at roughly 6.8 psi and at the moment I'm running the intercooler from the drag kit (which I believe is a spearco) and I'm not sure how much the pressure drop is but I'm just wondering why I'm not fully boosting the 6.8 or so psi in first and second gear. Thanks guys.
