hey guys i gotta fist size hole in my wall (lol dont ask)....anyways i know i cant just put that putty stuff right there but what can i use to cover it up so i can putty it and paint it
Cut a small piece of drywall to fill in the hole, then plaster it in place
cut out a chunk of the drywall and get a few scraps of wood.
say a 1 foot by one foot section.
put the wood behid the existing drywall and screw it in so that the wood is showing in the hole you cut out (is should be at the back of the drywall) do that on either side
then cut a new piece to go in (11 7/8 inches by 11 7/8 inches)
put it in the hole and screw it to the wood that you mounted. (you should now have a 1/8 gap to fill arountd the new chunk of drywall) you can use drywall tape and mud to fill that gap, but makes sure you put it on lightly so you can blend it into the existing wall.
sand it down prime and paint.
and learn not to punch walls.
hah
use that link
it explains it almost as good as me!
