hi
i have a GARRETT M27 turbo built for a disel engine
can i used in a gas engine ??
is it possible ??
what are the different between a gas and disel turbo ??
thanks in advance
hi
is it possible ??
thanks in advance
Dont try
I would imagine the turbo is suited to the engine it was designed for. Seeing as most diesels are low-rev torque machines I wouldn't expect the turbo to be any good on a low displacment high revving engine.
I'm not familiar with that turbo but alot of the large turbo's used on compact cars were designed for diesel engines so the answer is yes depending of the orientation of the exhaust and compressor inlets and if it's too large or not a good match for your application.
diesel motors are low rpm and the turbos are designed for that specific application. Gas turbos are designed for high rpm.
It's not all about RPM boys, it's displacement and exhaust flow. A large deisel engine will flow more exhaust at a lower RPM than a small 4-cylinder engine running at a higher RPM.Originally posted by alpineguy
I don't see any reason why it wouldn't work..
Alot of people post without knowing shit. DSM'ers have been using Holset diesel turbos for years. Turbochargers are fundementally the same whether they are on a gas engine or diesel engine, only the sizing varies. Diesel turbo's will usually be larger like the 50 trim variety and up (diesel engines run higher boost in alot of applications) so you have to ensure that it will fit your application as I said before.
a lot of the turbo ford guys, and just recently the turbo dodge guys, are using holsets as well with great success. decent choice if you have a motor with decent displacement and don't want to spend a lot on a turbo.Originally posted by heavyD
Same concept? sorta... Someone confirm meOriginally posted by SAiamNE
Correct me if I'm wrong but don't (most??) diesel turbos have no WG?
Apparently they can take alot of abuse and provide alot of bang for the buck.Originally posted by finboy
a guy in town used one on his GLH and was pulling consistent 111-112 mph on a 2.5L four, and i think you can snatch them off ebay for around $400Originally posted by heavyD
the exhaust housing is usually the difference. compressor A/R's usually stay in the 60-70 range while the exhaust side is in the 1.18's.....
Exactly, as long as the trims and flanges will work for your application, use it....
