Western Digital Raptor SATA 36Gig 10Krpm
Tree View
HOME HardDrive
Item Code : HDDWDC-RAP36G
Category: HardDrive
Model : Western Digital Raptor
InStock : Yes
Manufacturer : Western Digital Corporation
Price/Cash-Debit: $164.79 / $159.99
Printer friendly version Email friendly link (Use this link to email this item to a friend.)
Description:
The exploding growth of enterprise data storage puts tremendous pressure on IT managers, who must accommodate ever-greater volume with ever-tighter budgets. This increased need for enterprise storage, coupled with the decline in IT budgets, creates a need for reliable, low-cost solutions. Enter Serial ATA (SATA), a new interface developed with enterprise storage in mind. Some hard drive companies design desktop-class hard drives with the SATA interface, but WD is going one better. To meet the demands of enterprise storage, Western Digital is the only company to combine an enterprise-class hard drive with the SATA interface to meet all the demands of the enterprise environment—reliability, performance, and reduced cost.
A NEW BREED OF HARD DRIVE
Serial ATA is poised to replace Parallel SCSI in the mid-range, but only if there's a drive that can meet the performance and reliability requirements of that market. That drive is the WD Raptor! The WD Raptor is a new class of hard drive that matches SCSI performance and reliability and provides simplified connectivity, all at up to 30 percent less cost than Parallel SCSI drives.
WD RAPTOR PRODUCT BENEFITS
Built for speed, the WD Raptor has 10,000 RPM rotational disk speed and 5.2 ms average data seek times.
Built for reliability, it has a rugged, enterprise-class mechanical platform with high-end bearings and actuator.
Built to last, this Enterprise SATA (ESATA) hard drive is made for years of high-performance operation around the clock. MTBF has been calculated at 1.2 million hours.
Built with a backing, WD Raptor ESATA hard drives carry Western Digital's five-year warranty.
Built for value, WD Raptor is priced up to a third lower than Parallel SCSI enterprise hard drives.
FOR BUSINESS-CRITICAL APPLICATIONS
Mid-range to high-end Storage Area Network (SAN) and network-attached storage (NAS) applications
Department and mid-range servers
Dual-processor workstations
Physical Specifications
Capacity 36.7 GB
Areal Density 36.7 GB
Model Number WD360GD
Formatted Capacity 1 37,019 MB
User Sectors Per Drive 72,303,840
(44F44E0h)
Interface Max 1.5 Gb PHY
serial Interface
Bytes Per Sector 512
Dedicated Landing Zone Yes
Actuator Latch/Auto Park Yes
Performance Specifications
Data Transfer Rate
- Buffer to Host
- Buffer to Disk
150 MB/s max 2
102 MB/s max
Average Read Seek 5.2 ms (average)
Track-to-track Seek 3 0.7 ms (average)
Full Stroke Read Seek 3 10.2 ms (average)
Average Latency 2.99 ms
Rotational Speed 10,000 RPM
Read Cache Adaptive
Write Cache Yes
Buffer 8 MB
Drive Ready Time 7.0 sec average
Start/Stop Cycles 20,000 min
Error Rate
(non-recoverable) < 1 in 1015 bits read
Physical Dimensions
Height 1.028 in. (25.4 mm) max
Length 5.787 in. (147.0 mm) max
Width 4.0 in. (101.6 mm) ± .01 in.
Weight 1.60 lb. (0.73 kg) ± 10%
Power Requirements 4
Mode 12 V (± 10%) 5 V (± 5%) Power
Read / Write 430 mA 925 mA 9.75 W
Idle 350 mA 5 850 mA 9.25 W
Standby 25.5 mA 350 mA 2.1 W
Sleep 25.75 mA 200 mA 1.3 W
3.3 V Serial ATA power not used in this product.
Environmental Specifications 6
Shock
Operating 20 G (write), 65 G (read)
Non-operating 250 G
Half sine wave measured in 2 ms duration, measured without isolation.
Vibration
Operating - Random 0.008 g2/Hz (10 to 300 Hz)
0.0012 g2/Hz (300 to 500 Hz)
- Linear 10-300 Hz, 3.0G (0 to peak)
300-500 Hz, 0.5G (0 to peak)
- Rotary 30 rad/s2 (10 to 500 Hz)
Non-operating - Random 0.05 g2 /Hz (10 to 300 Hz)
- Linear 10-300 Hz, 5.0G (0 to peak)
Operating Temperature and Humidity
Temperature 5°C to 55°C
Humidity 5-95% RH non-condensing
Thermal Gradient 20°C/hour (maximum)
Non-Operating Temperature and Humidity
Temperature -40°C to 65°C
Thermal Gradient 30°C/hour
Acoustics (average)
Idle Mode 32 dBA average
Seek Mode 36 dBA
Reliability
MTBF 7 1,200,000 hours
Warranty 5 years
1Western Digital defines a megabyte (MB) as 1,000,000 bytes, and a gigabyte (GB) as 1,000,000,000 bytes.
2Maximum burst rate running the specified PIO, DMA, Ultra ATA, or Serial ATA transfer mode.
3On reads and writes.
4After 24 power on hours.
5Average current.
6No non-recoverable errors during operating tests or after non-operating tests.
7100% duty cycle at 50° C on base casting.
