95 Buick Century 3.1 oil pan drain plug - Beyond.ca - Car Forums
Results 1 to 7 of 7
Thread: 95 Buick Century 3.1 oil pan drain plug
    Edmonton Alberta
    '83 GoldWing, from coast to coast. Twice.
    Default 95 Buick Century 3.1 oil pan drain plug
    What size socket fits the oil pan drain plug on a '95 Buick Century 3.1 ?
    Johnny R
    Of the top of my head 14mm, could be wrong though.
    Aug 2004
    Vice grips....
    2011 Ram 1500 QC Sport
    2017 Jeep Cherokee Limited
    Jan 2005
    Z
    14mm or 15mm most gms are the same
    Edmonton Alberta
    Thanks - it was 15 mm. How much torque should I give it to reinstall it?
    Johnny R
    Jan 2005
    Z
    Put it finger tight then a half turn at most if it requires a gasket or buit in gasket, Not super tight though!!
    Depends if u want to do the next oil change or if u ur getting someone else to next time.
    Gasket, half turn should do, basically go until it gets really hard to push so your using all your force, that should be enough. If you go too much u may ruin the gasket or crack the oil pan, too little and it will wobble loose and drain ur oil then ur fucked.
  1. FS : 1985 Buick century
    By d-UNiT in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 10-21-2004, 09:56 PM
  2. FS: '89 Buick Century
    By ed_1109 in forum Cars, Trucks, Motorbikes, and Trailers
    Latest Threads: 09-29-2004, 11:06 AM
  3. 95 Buick Century daytime running lights module
    By John R in forum Mechanical
    Latest Threads: 09-03-2004, 08:06 PM
  4. Tranny Drain plug
    By Daxin in forum Mechanical
    Latest Threads: 11-04-2003, 02:04 PM
  5. where is the radiator plug to drain my radiator?
    By EstoMax in forum Mechanical
    Latest Threads: 09-27-2003, 08:34 PM
