only gettin 4 psi??? boost leak? vac leak? - Beyond.ca - Car Forums
Results 1 to 12 of 12
Thread: only gettin 4 psi??? boost leak? vac leak?
    Jan 2003
    2001 Grand am 2.4L
    Default only gettin 4 psi??? boost leak? vac leak?
    my wastegate is set at 5.8 and i think i might have a boost leak or somthing. My boost gauge is connected to the vac seen by the fpr should it be there?..or at the throttle body. anddd if its a boost leak is there any way to test for a boost leak? anything would help. thanx guys
    Jan 2005
    Devon, AB
    89 Shelby daytona
    pull the lvac line to the wastegate and see if that number rockets up. usually has to deal with wastegate. If there was a sever boost leak through your piping you should be able to hear it.....
    connected to vac seen by fpr.....yes that line should give you accurate boost readings. If it is like my daytona the fuel pressure will rise/fall based on vac/boost that is fed to it through that vac line, so it better be accurate.....
    May 2003
    DC4, CB750, CB360t
    go through all your clamps on the IC piping
    check and recheck your couplers
    it's amazing what a small leak can do to your boost
    May 2005
    lol.... 5.8 is what your wastegate sees.......... but your boost guage tapped at the intake manifold sees 4..... sounds like you got a pressure drop across the intercooler and chargepiping.... combine that with the inaccuracies of your boost gauge and wastegate and thats where your 1.8 psi went....
    May 2005
    actually not really, I had a 1' diamter hole in my charge piping as was still able to boost over 5 psi...
    Jan 2003
    2001 Grand am 2.4L
    yah i gotta check the couplers , im almost positive that it isnt the spot where i tapped, cause my emanage sees 3.75 psi aswell, but i have no idea ...ima check over the couplers, and ima try that wastegate thing also. ill get back to you guys, thanx for the feedback
    Nov 2004
    Medicine Hat Alberta
    72' Standard
    Jan 2003
    2001 Grand am 2.4L
    hey guys, i took the vac line off the wastegate and it rocketed up to 7 psi, haha tons of power woooo LOL...but yah i gotta check for a leak coming from around my wastegate/turbo area the bottom side of my wastegate bolts are soooo hard to get at and i think thats the spot where its leaking, u think a small little leak in the wastegate would cause 2 psi loss, most likely hey, i duno im gonna try my hardest to tighten these bolts and ill get back to you guys asap, just got my exhaust done sounds goood 2, but ughhh sumthing is ratteling haha anyways thanx guys
    Mar 2006
    tampa florida
    1998 Eclipse GST
    Im kind of having the same problem, I have a 98 Eclipse GST and the boost wont go higher then 3 to 4 pounds, I checked for leaks, and nothing, I dont get whats wrong
    May 2003
    2015 Ram 1500
    I would check the upper/lower intercooler pipes...I used to blow my upper IC pipe off on a regular basis...if you are still running the stock 2G MAS sensor it will run like crap if it's around there...check all your vacum lines for cracks, that would be a good start...
    Originally posted by HeavyD
    you know you are making the right decision if Toma opposes it.
    Medicine Hat
    90 jdm ST185 86 ST162
    Are you sure that your wastegate is opening and closing all the way? If it does not fully close you will definately lose some PSI. Happened to a guy I know who turbo'd his 5SFE in his Camry, he was only producing 4 PSI and his wastegate wasnt closing all the way. He got this fixed now he's boostin an efficient 7-8 PSI.
  1. Boost leak tester
    By JCX in forum Forced Induction Talk
    Latest Threads: 06-04-2005, 05:20 PM
  2. Local source for Silicone Vac lines
    By thebracko in forum General Car/Bike Talk
    Latest Threads: 08-24-2004, 03:17 PM
  3. Replies: 3
    Latest Threads: 05-22-2004, 07:58 AM
  4. Help!!! Boost leak w/ my 1.8T
    By R-Audi in forum Mechanical
    Latest Threads: 05-02-2004, 02:25 PM
  5. 16.5 psi Boost in a SOHC
    By egmike in forum Cars, Bikes, Machines
    Latest Threads: 03-14-2003, 06:26 PM
