Vehicle stats:
1991 GMC Vandura 3500 Cutaway Cube Van.
14 ft Intercontinental Bodies box.
sliding rear door with cargo access door from cab.
dually.
White.
air bag equipped up front.
Tare: 3200 KG
GVRW around 4500 KG
Tires rated for 6020 KG
Features:
Automatic
Power steering
AM/FM/Tape radio (2 speaker)
350 on Propane, there is gas tank as well, so it might take both. Gas is so expensive that I just use propane. Two tanks
LED brake lights for safety
Rubber floor in cab
Wood floor in box
New parts:
Transmission was rebuilt 13 000 KMS ago. Still has remainder of 17 000 KM Warranty from Mr. Transmission. This cost over $3000.00
New ECU - Mr. Transmission wasn't sure what was wrong with the van, so they replaced that too.
Fan Belt - 2000 KM ago
Spark Plugs/distributor cab/rotor - Two months ago
Exhaust - Done 1.5 Years ago. Still looks brand new!
Battery/Alternator - Done at the same time in November
U-Joints - Done in summer of 2004
Wipers
Rear wheel bearings
Outer tie rods
Motor and Driveline
engine:325 000 KM on it. A combination of city and highway. This motor runs like new. There are no propane smells, no burning and the oil comes out clean at every oil change. The Differential had new fluids put in it at the same time as the transmission (December)
Transmission: basically brand new, comes with a 17 000 KM warranty on it still.
U-Joints: good
Differential: good to go, serviced regularly.
Safety:
Rear Brakes: 75%
Front Brakes: 50% (However, if the buyer is willing to give me 15min to change them, I will do that at no charge)
Tires: Are in fair condition - Recommend replacement around the start of Winter 2005
New windshield and seal are needed.
Recently had new bearings installed on the rear wheels.
PRICE: $5300.00obo
PM me for more pictures or info. I can bring this van to you if you want to see it in person....within Calgary. haha
