Deck Problem?!? - Beyond.ca - Car Forums
Results 1 to 10 of 10
Thread: Deck Problem?!?
    Dec 2002
    EF ZC-T, EK-T, Blazer, EF
    Default Deck Problem?!?
    Well i have had my deck in my car since september. I bought it at the Big 4 sale. Today i was driving and all my trebble cut out and all i got was the sub. I check all the connection and it still does it. What could the problem be?
    Thank in advance.
    Dec 2002
    could be blown high level fuse, or fried channels. assume the fuse first.
    Dec 2002
    where would this fuse be? it cuts in and out thou?
    Sep 2002
    Vagabond Backpacker
    Boeing, Airbus
    I'd say re-check the connections and check the ground. Other than that it could be an internal thing.
    Dec 2002
    that what i thought i checked everything today and it is all fine. i went to sounfdaround they wany want to charge me 40 buck to check the wiring i said it was fine. he said they have to check. this is bull shit
    Jul 2002
    make sure u didnt run ur power line and ur rca's etc. along the same path......they should be kept apart....my buddy ran them to the sub/amp all together and he had the same problem
    Built not Bought.
    Dec 2002
    really? i have been running all wire together since steptember and it just started. i will try moving the apart. thank
    Dec 2002
    the fuse i'm talking about is a little one on the decks harness. sometimes they keep it in a little black box with the wiring. either way, it's inline.
    Sep 2002
    I dont Drive
    Sorry for assuming, but is this a factory deck or aftermarktet??
    if its factory just take it back and they will fix it. if its aftermarket,
    dont be suprised if its actually the deck itself doing it. not all problems can be solved by replacing fuses. but as said a million times before, check all your connections, and if your full range speakers are amped (factory) make sure the amps ok...
    just out of curiosity what kind of vehicle is it??
    BTW this wont do anything like cut sound out all together , all you`ll here is heavy power buzz. wont effect the volume of individual channels at all.
    Dec 2002
    well it is a 91 Civic. it is an aftermarket deck. i will check eveything again. i will let u know how it truns out.
  1. Deck Installation problem Any suggestions?
    By driz6 in forum In Car Entertainment / Electronics
    Latest Threads: 03-19-2003, 12:38 AM
  2. Exhaust problem
    By sexualbanana in forum General Car/Bike Talk
    Latest Threads: 08-17-2002, 09:50 PM
  3. Amp problem
    By redline_13000 in forum In Car Entertainment / Electronics
    Latest Threads: 08-17-2002, 12:41 PM
  4. Problem
    By [GaGe] in forum Suggestion/Comment Box/Forum Related Stuff
    Latest Threads: 08-04-2002, 02:38 PM
  5. Engine Oil Problem
    By hingkit in forum Mechanical
    Latest Threads: 06-16-2002, 09:33 AM
