Please email me at [email protected] if you have one.
turner works 14.95$Originally posted by gaubien
Do you remember what kind? When did you buy it?
2 months ago o e mOriginally posted by gaubien
its all about the ground control rear shock mounts on e36
What does that mean? I do not get it. Would appreciate some elaboration.
Ground control makes one of the the best RSM for bmw's.
Other alternatives is Rogue Engineering RSM.
If you dont wanna dish out the extra dough for it, you can get the Z3 RSM or the E36 convertible RSM's (They are stronger but will eventually wreck later)
an alternative "upgrade" can be found here:
http://www.understeer.com/onlinestore-suspension.shtml
E36 Suspension Install Kit - $99
this can be bought at tunerworks aswell and most likely cheaper
E46 convertable mounts +z3 reinforcement plates are the best OEM solution. any E36/E46 mount will work, the only differences are the rubber compound(based on the cars weight, etc.) Since convertables are heavier they have stronger mounts.
thanks all for explaining.
