2002 Mazda Protege 5 Turbo (MP5T)
Here is one of my cars. A 2002 Mazda Protege 5 Turbo. It's taken over 3 Years to complete and it's all Custom and Basically, the manifold is the only thing I didn't make.
![](http://memimage.cardomain.net/member_images/11/web/503000-503999/503974_190_full.jpg)
2002 White Mazda MP5 Turbo 2.0L 16V DOHC Manual 16.5/25.5 PSI Daily/Switch
Garret Custom GT-28s Liquid cooled Ball Bearing (Disco Potato)
8.5:1 Low Compression CP Forged Pistons 4 Ring
Forged Oliver Rods, Brass Bushing, TOGA Rod Berings, TOGA Mains,ARP Rod Bolts.
SDS EIC2 Extra Injector Controller System.
Full Crank Balance, Deck/Head, Deglaze, Align Hone.
Intake Manifold Extrudehoned, Primary VCTS Disabled
Head Extrudehoned, ARP Head Studs
Tri Point Adjustable Timing Gear
304 Stainless 4to1 Turbo Manifold
Exaust Manifold Extrudehoned.
DEI Header Wrap
2.75" Turbo Back Exaust
Apex-I N1
Spearco Full Front Intercooler
Stand Alone Liquid Turbo Cooler
T-6 Ron Davis Prototype Triple Pass Radiator, 21 Psi
Enki CDR-9 18"Alloy Rims
Yokohama Parda Spec-2 215/35Z18
KVR Nickel Plated Cross Drilled Rotors
Sparco Torino Seats w/4 Point
TEIN - SS Full Suspension
AWR Motor Mounts
AWR Adjustable End Links
AWR 21 MM Anti Sway
ACT Stage IIR Clutch
Turbo XS Bov-RFL
Tial 35mm Wastegate 15 Psi Spring
Turbosmart Dual Boost Controler
Vibrant Silicon Hose Set (Black)
Apex-I Turbo Timer
Autometer Boost 30 Vac/30Boost
Autometer Stoych Air/Fuel
Autometer Oil Pressure
Autometer EGT (Pyrometer)
Autometer Tachometer Adaptor
Optima Gold Top Deep Cycle Battery
Kenwood Audio System
Phoenix Gold ZX-475 Ti Amp
Phoenix Gold Bass Cube Ti
JL Audio 12W3 D6 3 Ohm Bridged
Crappy Red Neon (Under Dash)
Ghetto Tinting
Ricey Stickers (50HP+) Woot Woot!
http://forums.beyond.ca/showthread.php?s=&threadid=92259
